Author Topic: 215 Explorer. Cuddy question Seabob???  (Read 880 times)
April 27, 2020, 02:14:43 PM
Read 880 times
waterman
« on: April 27, 2020, 02:14:43 PM »
Hey guys. Wondering inside the cuddy cabin is all molded 1 piece  except what is the area inside the cuddy that is a panel and screwed in I’ve never taken it apart but was wondering what it is for and does it access something??? Will try to post a pic. Thanks
April 27, 2020, 02:53:11 PM
Re: 215 Explorer. Cuddy question Seabob???
« Reply #1 on: April 27, 2020, 02:53:11 PM »
I ain't Seabob but I would guess he's not going to respond so...
Yes a pic would be most helpful. Is it facing the helm? If so, then it's an access panel to your wiring/gauges/steering.
Facing forward toward the bow? Could be access to the anchor rode.
Again a pic would certainly narrow it down.
Good luck. :thumright:
April 27, 2020, 08:19:24 PM
« Reply #2 on: April 27, 2020, 08:19:24 PM »
A lot of us have Explorers - what year do you have? And yes pics will help.
April 29, 2020, 12:47:12 PM
waterman
« Reply #3 on: April 29, 2020, 12:47:12 PM »
I  have a 1998 explorer 215. I will try to post a picture if it  will let me
April 29, 2020, 12:48:28 PM
waterman
« Reply #4 on: April 29, 2020, 12:48:28 PM »
That is inside cabin port side right at the door area
April 29, 2020, 01:15:13 PM
« Reply #5 on: April 29, 2020, 01:15:13 PM »
That is a cover plate. There was an optional sink module for that model which fit in that spot. I did need to do a little searching but found a video showing the sink on a Wellcraft 210 Coastal which is what you have, just re-badged as an Aqua 215 EX.
https://www.dailymotion.com/video/x3wzzt7
4.25 minutes into the video. Listen to the description. Notice he mentions what the cabin is without the sink.
April 29, 2020, 06:26:44 PM
« Reply #6 on: April 29, 2020, 06:26:44 PM »
You'll have better luck with your pic posting if you follow the instructions here http://classicaquasport.com/smf/index.php?topic=12725.0  - don't attach them - you are limited by file size. Uploading them into your personal gallery is better for viewing.
Spend a few minutes to absorb the instructions. It's really easy. Remember if using a phone to take pics, to hold the phone horizontal with the lens to the left.
April 30, 2020, 12:04:31 PM
waterman
« Reply #7 on: April 30, 2020, 12:04:31 PM »
.  Wow I had no idea about that  thanks for the reasearch and video. I have never seen an aquasport like mine with a sink in it  would love to install one  any ideas where you could get one of those ???
Thanks for the help
April 30, 2020, 01:02:48 PM
« Reply #8 on: April 30, 2020, 01:02:48 PM »
No idea at all. It might be a long, frustrating search but rewarding in the end if you found one.
Also, you may have or seen this already but if not, just another piece to add to your hull literature.
https://www.wellcraft.com/uploads/2016/3/OwnersManualWCCoastal2101.pdf
May 03, 2020, 10:47:54 AM
waterman
« Reply #9 on: May 03, 2020, 10:47:54 AM »
Great Thankyou for the info
