Author Topic: Performance on 225 ex with 225 yamaha 4 stroke?  (Read 307 times)
April 25, 2020, 08:06:10 PM
Read 307 times
adnan.begic1
« on: April 25, 2020, 08:06:10 PM »
I have a 95 225 explorer with a 225 yamaha pushing it, hoping someone else has this setup so i can get their performance numbers. I dont think my boats running quite the way it should, thanks!
April 26, 2020, 10:57:02 PM
boatnamesue
  • Jason
Re: Performance on 225 ex with 225 yamaha 4 stroke?
« Reply #1 on: April 26, 2020, 10:57:02 PM »
Find the spec rpm range at WOT for your model/year engine.  Then compare your rpms at WOT.  You should be at or near top end of range.
Jason
1976 AS 170
1998 S115TLRW
April 27, 2020, 07:06:16 PM
adnan.begic1
« Reply #2 on: April 27, 2020, 07:06:16 PM »
Cant check rpms, dont have a working gauge, just received a mew gauge and cant get it to work properly so until i find that out i wont really know what it is... thinking maybe a mix of fuel delivery issues and prop size.
April 27, 2020, 07:50:00 PM
boatnamesue
  • Jason
« Reply #3 on: April 27, 2020, 07:50:00 PM »
Rpms are the most valuable non-diagnostic metric when assessing engine performance.  Evaluating prop pitch cannot possibly be done correctly w/o knowing rpms. Getting your new rpm gauge working should be your priority #1.
Jason
1976 AS 170
1998 S115TLRW
April 27, 2020, 08:06:11 PM
« Reply #4 on: April 27, 2020, 08:06:11 PM »
Yeah you can't just buy any Yammy gauge - I had the same problem when I bought one.
April 27, 2020, 11:41:55 PM
adnan.begic1
« Reply #5 on: April 27, 2020, 11:41:55 PM »
How do i know what will work... i honestly dont even care about the trim sensor bc i can visually see and know where my trim is at, but i hope the oil pressure and overheating sensors are working on the gauge. Any way to know? When i hooked it up and turned the key switch, they blink once or twice and go away, does that mean that its reading right, or not at all.
April 28, 2020, 06:13:03 AM
« Reply #6 on: April 28, 2020, 06:13:03 AM »
I would google for an owners/service manual for the motor and  look in the owners manual for the engine and it should tell you the model gauges to use. I bought mine from a surplus place and had to return it because it wasn't compatible.
