Author Topic: I-pilot on a 225 explorer?  (Read 1195 times)
April 25, 2020, 07:04:38 PM
Read 1195 times
adnan.begic1
« on: April 25, 2020, 07:04:38 PM »
Has anyone put an ipilot system on a 225? Been trying to find some help with where to house batteries, how anyone has fabbed or made mounts for it to fit the hull. I have a 95 225 explorer and she sits kind of bow heavy so i wouldnt like to add the batteries in the bow but she also struggles to get onto plane sometimes(usually when the livewell is full) so i dont know how the weight will affect the aft either. Powered by a 2005 225 yamaha four stroke, and no trim tabs. Would the tabs help because i feel that the cutouts in the hull make pockets and drag a ton. I know this is a lot haha but anything helps. Thanks!
April 26, 2020, 06:40:12 AM
Re: I-pilot on a 225 explorer?
« Reply #1 on: April 26, 2020, 06:40:12 AM »
I don't think I would put an electric trolling motor on an Explorer - these boats are heavy and I don't think the trolling motor could handle it and if it could, with maybe a 36V system, the batteries wouldn't last long.  I have a friend that has a 20hp kicker on his - never saw it used but it was there.
April 26, 2020, 07:53:34 AM
« Reply #2 on: April 26, 2020, 07:53:34 AM »
Trim taps will help that hull a lot but.... is the prop itself correct? Is the motor mounted at the right height?
Post up some performance numbers.
I run a 150 4 stroke on my 210 which is similar to your hull without the Euro transom. I have tabs and they help get her up on a plane much quicker than without.
Good luck. :thumright:
April 26, 2020, 08:21:14 AM
adnan.begic1
« Reply #3 on: April 26, 2020, 08:21:14 AM »
We did adjust the mount height and got it to the right level and its running a 15 by 19 prop... thinking i need more like a 17 but havent seen one come up for sale yet and im not buying one new haha. Thanks for your input, the new minn kotas are supposed to hold up to around 10000 lb boats, so i went ahead and got one of the 112# with an 87 inch shaft... its a beast. Hopefully tabs will flatten out the running surface and help everything after all this stuff is done.
April 26, 2020, 08:27:57 AM
adnan.begic1
« Reply #4 on: April 26, 2020, 08:27:57 AM »
Sorry missed the part earlier.. just got a new gauge so will be able to see rpm and data, so i can see for sure if she’s running right. With full fuel, full fishing gear and ice and cooler, 2 people on board she does about 26 top end. The engine does bog out sometimes so i think i need to check the fuel delivery somewhere because we found the fitting onto the high pressure in the motor was lose and it was leaking, that fixed a lot haha but shes not yet fully there i believe.
April 26, 2020, 10:16:20 AM
« Reply #5 on: April 26, 2020, 10:16:20 AM »
Something ain't right. Below is the link to my hull with the 150. Granted, this was lightly loaded to create a baseline but fully loaded and 3 men aboard I can still hit 36 mph. I need to raise my height about another inch and that should help with the top end. I'm more about my cruising performance so WOT isn't my first concern and it took trying three different props to get where I'm currently at. These hulls are very similar in length, width but you have a heavier hull (dry with motor) but then you have 75 more ponies. That hull should do 40+ with little problem if everything is set up and running correctly.
http://classicaquasport.com/smf/index.php?topic=4608.msg144901#msg144901
April 26, 2020, 12:11:43 PM
« Reply #6 on: April 26, 2020, 12:11:43 PM »
I agree with CB - you should see 35+ mph.
So you bought the ipilot just for the sea anchor capability? Expensive anchor but I do agree, the ipilot is cool.
April 26, 2020, 01:13:10 PM
adnan.begic1
« Reply #7 on: April 26, 2020, 01:13:10 PM »
Yep lol tired of anchoring perfectly after 3 attempts just for the wind to change, this thing should be a game changer if we can get everything figured out. Working on it now and ran into gauge issues:(
April 26, 2020, 01:19:52 PM
adnan.begic1
« Reply #8 on: April 26, 2020, 01:19:52 PM »
Where on the forum would i look for help with my yamaha gauge and motor connections?
April 26, 2020, 01:35:50 PM
« Reply #9 on: April 26, 2020, 01:35:50 PM »
Other than a member with the same setup, we won't have what you're looking for here. A service manual is your best bet.
Start here.
https://www.emanualonline.com/Marines/Outboard-Engines/Yamaha/1998-_-2005-Yamaha-Outboard-Motor-Service-Repair-Manual.html?currency=USD&gclid=CjwKCAjw4pT1BRBUEiwAm5QuRxgCTt6EdzlaKwDom8LwXuMtRWP8wbYJFMbYQ3OCcXhIFFGOV424IBoCBs0QAvD_BwE
This is an Owner's Manual. I don't know what model motor you have so this might not pertain to you. While this won't give you wiring schematics and service repair like the link above, it will give you a general idea of your gauges and their functions along with other general knowledge.
https://www.maritimepropulsion.com/files/pdf/1001498
April 26, 2020, 08:07:04 PM
adnan.begic1
« Reply #10 on: April 26, 2020, 08:07:04 PM »
Ive already looked through and tried everything i could think of and couldnt figure anything out, model is 2005 225turd and the gauge is a 6y5-8350t-E0-00. The rpms seem to work but the trim sensor seems to be off, dont know if im using the wrong harness or if maybe a trim sensor is out. Hate roadblocks like these lol. But if anyones interested got the batteries installed and ran all the wiring, mocked up a mount for the trolling motor, installed tabs and tried to get the gauge done today. Next is stereo, 12v plug, and new helm.
April 26, 2020, 10:41:26 PM
« Reply #11 on: April 26, 2020, 10:41:26 PM »
First thing to check is the trim switch lever under the motor. They tend to stick after sitting for some time.
April 26, 2020, 10:49:35 PM
adnan.begic1
« Reply #12 on: April 26, 2020, 10:49:35 PM »
No its all good, put a whole new switch a few weeks ago, the old one snapped off lol, but it just doesnt register on the gauge what level it is at, wondering if ive got the wrong wires hooked up
April 27, 2020, 11:25:20 AM
« Reply #13 on: April 27, 2020, 11:25:20 AM »
Did you buy that gauge new to replace an older model?
Could that be D0-00 rather than E0-00 ending on the gauge #?
*2005 and newer Yamaha outboards that use the one plug trim and oil harness may require a 6Y5-85335-00-00 adapter harness in cases.*
SKU#: 6Y5-8350T-DO-00
Replaces OEM # 6Y5-8350T-83-00
I mention this because the same condition persists with earlier Yamaha multi gauges when using the model for 94 year 2 strokes on earlier model outboards. Yamaha switched the way the trim indicator was wired. I searched for some time to find an older (pre 94) gauge for my 91 200. Rick K experienced the same thing on his 92. It appears this has also occurred on the 2005 and later motors when using this gauge. If that's the case, you'll need to search for the adaptor harness for the gauge to function.
April 27, 2020, 02:16:51 PM
adnan.begic1
« Reply #14 on: April 27, 2020, 02:16:51 PM »
That really stinks... youd think theyd be plug and play but i guess not.
