Author Topic: Rectifier problem  (Read 396 times)
March 20, 2020, 07:38:32 PM
Read 396 times
Kenny
Rectifier problem
« on: March 20, 2020, 07:38:32 PM »
 1987 170 with 1987 Johnson 110 replaced rectifier worked for 40 minutes then quit working what could cause this
Well I should say the tach and the vote gauge dropped before I replaced it the tach would work until you got above 2000 RPMs now it does nothing
March 22, 2020, 08:34:38 PM
boatnamesue
  • Jason
Re: Rectifier problem
« Reply #1 on: March 22, 2020, 08:34:38 PM »
Jus curious....how did you come to conclusion the rectifier was the issue before replacing?
Jason
1976 AS 170
1998 S115TLRW
March 23, 2020, 04:40:56 PM
March 24, 2020, 09:29:08 PM
Kenny
« Reply #3 on: March 24, 2020, 09:29:08 PM »
It could be a loose wire haven’t had time to look but when I had it out this weekend it was working
I never checked it myself the guy I got it from was a mechanic and told me that was the only thing wrong with it and it did not charge according to the gauge and the tach did not work properly so I replaced it and everything worked for about 40 minutes or an hour and then it quit
March 28, 2020, 08:44:52 PM
Joeyn
« Reply #4 on: March 28, 2020, 08:44:52 PM »
a bad ground could make everything stop working
