Author Topic: water leak? 1980 Johnson 115 HP  (Read 292 times)
March 12, 2020, 07:42:22 PM
Read 292 times
rberry3000
« on: March 12, 2020, 07:42:22 PM »
I have a lot of water coming from around the top of the lower unit in areas that I don't think it should be. Take a look at my video and let me know what you think
https://www.youtube.com/watch?v=qc6B9ov3jOk
March 12, 2020, 09:49:18 PM
boatnamesue
  • Jason
Re: water leak? 1980 Johnson 115 HP
« Reply #1 on: March 12, 2020, 09:49:18 PM »
Water tube connects to top of water pump housing.  This has either become disconnected, partially dislodged, or the water tube itself is leaking.  If water is pissing out of telltale then the tube/pump connection is intact.  If it’s not pissing you should not run engine.  I’d drop the lower unit and inspect.
Jason
1976 AS 170
1998 S115TLRW
March 13, 2020, 06:40:32 AM
« Reply #2 on: March 13, 2020, 06:40:32 AM »
This photo is neither a Johnson 115 or circa 1980 but....
The water pump layout might be similar to this. The tube that Jason refers to fits in the hole at the rear of the pump housing (white). Be sure to inspect the tube for corrosion (as stated above), due to its age, up in the middle unit. It may be somewhat difficult to see and require removal/replacement.
Good luck. :thumright:
