Author Topic: '69 19-1 complete rebuild  (Read 3486 times)
January 17, 2023, 11:05:12 AM
Reply #60
Reiko1078
Re: '69 19-1 complete rebuild
« Reply #60 on: January 17, 2023, 11:05:12 AM »
Boat came out great! Exactly what I want to do on my 196.   Is that the stock console?
January 17, 2023, 03:09:08 PM
Reply #61
« Reply #61 on: January 17, 2023, 03:09:08 PM »
Geez, I forgot to add pix of the support of my tank
Dryfit:
More dry fit:
January 18, 2023, 10:06:02 AM
Reply #62
tylertarpon10
« Reply #62 on: January 18, 2023, 10:06:02 AM »
Thank you for the pictures, I actually may modify the stringers as you did for my tank! Did you use a 2x6 as a backer and then glassed it?
January 19, 2023, 05:55:11 AM
Reply #63
« Reply #63 on: January 19, 2023, 05:55:11 AM »
I made the stringers and bulkheads from scratch. I made these molds for them - left is for bulkheads and right is for stringers.
As for what I used to notch and form where the tank sits I used the left form above - it has a 90 degree side and bottom to it and I ended up with a "L" looking piece when hardened.
I notched the stringers and then pulled them out of the boat and laminated the ledge into the stringers while on saw horses.
January 23, 2023, 10:16:59 AM
Reply #64
tylertarpon10
« Reply #64 on: January 23, 2023, 10:16:59 AM »
That is some great work and thinking on the stringers! Thank you
