Author Topic: Through Hull Fitting  (Read 535 times)
January 15, 2020, 06:12:33 AM
Read 535 times
umecheme
  • NorthEast
« on: January 15, 2020, 06:12:33 AM »
Contemplating installing a through hull fitting while i have the deck off for a washdown pump.  I'm sure others on here have.  Good idea? Bad idea?  Obviously there is some risk with any hole in the hull.  Just looking for input.
Thanks in advance!
January 15, 2020, 06:38:11 AM
Re: Through Hull Fitting
« Reply #1 on: January 15, 2020, 06:38:11 AM »
Go for it.
January 15, 2020, 07:20:25 AM
« Reply #2 on: January 15, 2020, 07:20:25 AM »
Here's some light reading but what is the correct procedure for installation.
https://marinehowto.com/seacock-thru-hull-primer/
While not a consensus favorite, I used Marlon rather than brass/bronze. It has held up very well (install date 2010) and the valve handle is still intact (early flaw with these) and moves as free as the day installed.
good luck. :thumright:
January 15, 2020, 08:55:08 AM
« Reply #3 on: January 15, 2020, 08:55:08 AM »
Now is the time.  Washdown and live well can share the same through hull. Either T off the sea cock, or get a pump that offers fitting.  You definitely want a sea cock and access to use it  Either Marelon or bronze are good.  Avoid un reinforced plastic and stainless.  Stainless is great above the water line, but below, you’ll be fighting rust stains.  A scoop style strainer facing forward will assure that you gave good flow enemy at speed.
January 15, 2020, 05:15:45 PM
Kam05r6
« Reply #4 on: January 15, 2020, 05:15:45 PM »
Thats a very clean set up capt bob.  Can i ask what u did to make the pad the under the valve .
January 15, 2020, 08:41:27 PM
umecheme
  • NorthEast
« Reply #5 on: January 15, 2020, 08:41:27 PM »
You beat me to the punch Kam
January 15, 2020, 10:04:04 PM
« Reply #6 on: January 15, 2020, 10:04:04 PM »
The pad is plywood that has been encapsulated with epoxy resin (multiple coats) and cemented to the hull with epoxy thickened with cabosil to a "peanut butter" consistency.  It was then painted with white "bilge coat" paint. The seacock is mounted with three "thru bolts".
