Author Topic: 170 trolling motor shaft lenght  (Read 1013 times)
January 14, 2020, 07:10:27 AM
Read 1013 times
alandry100
« on: January 14, 2020, 07:10:27 AM »
Wondering if anyone has had experience with a 54" shaft on a 170. I know the consensus is that a 60" shaft is best .. but if someone were to find a good deal on a shorter one is it ok?
79\' 170
2005 Yamaha 70 two stroke
January 14, 2020, 07:54:52 AM
CTsalt12
Re: 170 trolling motor shaft lenght
« Reply #1 on: January 14, 2020, 07:54:52 AM »
Yeah I’ve got one.  It’s fine.  On rough days if you’ve got a 2 ft chop while using spot lock
It will come out of the water, yes.  It’s not prohibitive or a deal breaker IMO.  Did you post this question on a Facebook group too?
Jimbo
1989 175 Osprey
January 14, 2020, 08:33:41 AM
alandry100
« Reply #2 on: January 14, 2020, 08:33:41 AM »
Thanks for the info - I did not post on facebook - but ... there is an Aquasport facebook group?
79\' 170
January 14, 2020, 11:22:39 AM
« Reply #3 on: January 14, 2020, 11:22:39 AM »
Not associated with this Forum.
There is one for the Boat Club site.
January 16, 2020, 10:14:19 PM
boatnamesue
  • Jason
« Reply #4 on: January 16, 2020, 10:14:19 PM »
I have minn Kota 52” on my ‘76 170, mounted on 1/2” blocks.....plenty of shaft, including rough seas.  A 60” shaft on a 170 would stretch nearly have the length of hull and hang way over the rail when stowed....way too much shaft.  The 22-2’s mount the 60”.
Jason
1976 AS 170
1998 S115TLRW
January 17, 2020, 09:56:12 AM
alandry100
« Reply #5 on: January 17, 2020, 09:56:12 AM »
Thanks - Is that a 12 or 24V model. I am wondering - for storage reasons. I need to keep 4 type I PFD's aboard so space is limited.
79\' 170
January 17, 2020, 11:39:54 AM
TooLoose
« Reply #6 on: January 17, 2020, 11:39:54 AM »
I'd suggest a 24volt. I have a 60" shaft and it does come in handy if fishing off the beach or around passes where the waves could kick up a bit. I wouldn't go back to a 54", but would certainly be fine if fishing flats only.
January 17, 2020, 06:19:12 PM
« Reply #7 on: January 17, 2020, 06:19:12 PM »
X2 on a 60"
January 17, 2020, 09:33:50 PM
boatnamesue
  • Jason
« Reply #8 on: January 17, 2020, 09:33:50 PM »
24v....unless you run numerous accessories that pull big amps like a stereo, you’ll only need 3 12v batteries.  Isolate your cranking battery of course, then run accessories off 1 of the 2 12v.  Recharge same 2 batteries during storage.
Jason
1976 AS 170
1998 S115TLRW
