Thanks for the info - I did not post on facebook - but ... there is an Aquasport facebook group?
Wondering if anyone has had experience with a 54" shaft on a 170. I know the consensus is that a 60" shaft is best .. but if someone were to find a good deal on a shorter one is it ok?
Quote from: alandry100 on January 14, 2020, 07:10:27 AMWondering if anyone has had experience with a 54" shaft on a 170. I know the consensus is that a 60" shaft is best .. but if someone were to find a good deal on a shorter one is it ok?I have minn Kota 52” on my ‘76 170, mounted on 1/2” blocks.....plenty of shaft, including rough seas. A 60” shaft on a 170 would stretch nearly have the length of hull and hang way over the rail when stowed....way too much shaft. The 22-2’s mount the 60”.
Quote from: boatnamesue on January 16, 2020, 10:14:19 PMQuote from: alandry100 on January 14, 2020, 07:10:27 AMWondering if anyone has had experience with a 54" shaft on a 170. I know the consensus is that a 60" shaft is best .. but if someone were to find a good deal on a shorter one is it ok?I have minn Kota 52” on my ‘76 170, mounted on 1/2” blocks.....plenty of shaft, including rough seas. A 60” shaft on a 170 would stretch nearly have the length of hull and hang way over the rail when stowed....way too much shaft. The 22-2’s mount the 60”. Thanks - Is that a 12 or 24V model. I am wondering - for storage reasons. I need to keep 4 type I PFD's aboard so space is limited.
