Props
Prop for 1997 215 DC w/OptiMax 225
Topic: Prop for 1997 215 DC w/OptiMax 225 (Read 836 times)
January 03, 2020, 01:28:37 PM
Read 836 times
sfernand
January 03, 2020, 01:28:37 PM »
Newbie here, to CAS.com, Aquasport, and powerboating for that matter. Recently got into a 1997 215 DC with an Opti 225, still shaking her down and doing a light refit.
Using the boat inshore, out of Punta Gorda, FL. Boat’s got a good hole shot, even loaded with a half dozen ppl and gear, but she tops out at ~35mph at the rev alarm, ~5600rpm on dash tach.
Bottom is clean, except for ablative the PO applied.
The prop on the boat is aluminum, not sure what make/dia/pitch, and I’m remote for next couple of weeks. Plan is to pull prop and head to the local dealer with the setup/performance story, but would really appreciate any beta based on firsthand experience.
Would like to accomplish a couple things. First, want to go wide open w/o hitting alarm/ limiter. Second, a very close second, I’d like to see top end of 40mph+ like I read about these boats doing.
Cheers!
January 03, 2020, 03:27:49 PM
Mechanical Master
Re: Prop for 1997 215 DC w/OptiMax 225
January 03, 2020, 03:27:49 PM »
I would bet you have a 17 pitch prop, which might be under-propped for that boat. I've got a 19 aluminum and a couple 20 stainless props laying around in the shop that should be about right for your boat with a 225 Merc. They are not doing me any good sitting here, so make a offer!
January 03, 2020, 05:55:51 PM
sfernand
January 03, 2020, 05:55:51 PM »
Thanks Cap!
Can you give a little more info ? diameters / makes ( models) ? history / condition ? were these on your Opti ?
Honestly, I'd like to try / have both a milder aluminum and more aggressive ss... be pretty cool to play with, prob learn a bit.
I am certainly game, but would like to be able to do a little research/thinking on it before pulling the trigger!
January 07, 2020, 03:35:22 PM
Mechanical Master
January 07, 2020, 03:35:22 PM »
If you want to pay the freight, I can send one or two to you to try. Keep it if you like or send it back. I'm not looking to make money here - just helping another Aquasport owner- so maybe $75 for the aluminum and $150 for the stainless if you want to keep it. I have another, very nice 4-blade stainless that I got recently to try on my boat. I don't really expect it to be better than what is currently on there, but either way I will have another prop to get gone soon. It seems I'm always looking for the "perfect" prop and have collected a few over the years.
January 07, 2020, 06:29:06 PM
January 07, 2020, 06:29:06 PM »
sounds like your under propped. My buddy has a 215 Explorer with a 175 Evinrude and he can hit 40mph. Your engine might be mounted too low as well. Hit was and he gained 5 or 8 mph by moving it up one bolt.
You have to get her up on a level plane and trimmed up properly and see where the cavitation plate is riding on the water. It should be riding on top of the water and you should be able to see it.
Here is a video of me testing the mounting height of the Etec on my 245 Explorer.
And a second video taken after moving it up a notch:
January 16, 2020, 10:26:25 PM
boatnamesue
Jason
January 16, 2020, 10:26:25 PM »
Engine height looks perfect....AV plate can be seen glazing top of water. You need to prop test w/just you, tank full, on a calm day and calm water. If rev alarm still triggers then increase prop pitch 2-4”. Need to know the pitch prop currently installed, of course. Speed is secondary to rpms....dial in the pitch to allow top end of rpm range at WOT. Once there, the speed you got at WOT is all your gonna get.
Jason
1976 AS 170
1998 S115TLRW
Props
