Author Topic: 19-1 or 19-6  (Read 794 times)
October 31, 2019, 07:48:47 PM
Read 794 times
Binkspot
19-1 or 19-6
« on: October 31, 2019, 07:48:47 PM »
Long time lurker, first time caller. Toying with the idea of picking up a new project boat to do over the winter, would really like to do a Aquasport. I am no stranger to the work just looking for information on the 19-1 and 19-6 (1973?). Both are available relatively close and was wondering if one would be a better choice based on ride and performance or any other factors. Both are total basket cases needing about the same amount of work. Thanks in advance.
November 01, 2019, 10:25:19 AM
Re: 19-1 or 19-6
« Reply #1 on: November 01, 2019, 10:25:19 AM »
1971 or 1972 were the last years for the 19-1.  Then came the 19-6 and then the 200.  Which one - 19-1 or 19-6?  It depends on your preferences.  The 19-1 is the early model with less deadrise and a simple hull shape that came from the Sargent-Coburn design that was originally in plywood.  The 19-6 is a later design that includes some forward lifting strakes.  The 19-6 will ride and perform better, but does not have the "classic" look of the 19-1.  The 19-6 takes 1" more water to float than a 19-1.  The build quality of the early boats was variable - some were put together well - some not so much.  Both had wood-cored decks and transom with the foam-filled fiberglass stringers.
it comes down to looks versus practicality.  The 19-6 is probably a better boat, but some folks love the look of the old 19-1 and 22-2 boats.  Browse through the Gallery section and you can find pictures of both with nice rebuild descriptions as well.
Hope this helps - good luck and welcome!   :welcome01:
November 02, 2019, 07:17:43 AM
Binkspot
Re: 19-1 or 19-6
« Reply #2 on: November 02, 2019, 07:17:43 AM »
Thank you, exactly what I was looking for.
