Gallery
Gallery
Aquasport Discussion
170 prep before paint question
Topic: 170 prep before paint question (Read 1037 times)
October 30, 2019, 09:25:16 PM
Read 1037 times
Bat21
October 30, 2019, 09:25:16 PM »
Hi all looking for some advice. Getting ready to repaint my 170.
In the process of removing rubrail, railing,rod holders etc... everything is embedded with silicon caulk. Is there a product to help remove the silicon from the boat?
October 31, 2019, 06:54:29 AM
Re: 170 prep before paint question
October 31, 2019, 06:54:29 AM »
Putty knife?
October 31, 2019, 11:11:15 AM
Bat21
October 31, 2019, 11:11:15 AM »
yes i am using a putty knife but its doing damage sometimes, i thought there may b a product to help remove the silicon, its also on my nonskid surface and the putty knife destroys the finish
October 31, 2019, 01:31:01 PM
outboardsurplus
October 31, 2019, 01:31:01 PM »
Sounds like it is not silacone but 5200,that is a bitch to get loose
October 31, 2019, 02:16:44 PM
October 31, 2019, 02:16:44 PM »
If 5200, there’s a product called debond, available at West Marine that will soften it.
October 31, 2019, 03:41:36 PM
Bat21
October 31, 2019, 03:41:36 PM »
its not 5200 its just silicon caulk but i cant get it all off, it has to b completely off before i paint the boat and the scraper leaves a thin coat behind, just went on the debond website and watched a couple videos on youtube and i think this is what im looking for, i don't want to sand the silicon off im only going to sand it into the paint (the boat was painted once already ). going to west marine tomorrow and will let everyone know how the debond worked, thanks again great website.
October 31, 2019, 03:48:09 PM
October 31, 2019, 03:48:09 PM »
maybe a wire wheel gently?
November 01, 2019, 01:10:12 PM
Fish Head
MidWest
November 01, 2019, 01:10:12 PM »
Found this online
Search Results
Featured snippet from the web
How to Remove Silicone Caulk Residue
Use a razor blade to scrape off as much of the residue as possible without scratching the surface you are cleaning.
Apply mineral spirits or denatured alcohol. ...
Brush away any bits that "pill" and become detached. ...
Repeat this process until all the caulk residue is removed
November 01, 2019, 05:48:39 PM
Bat21
November 01, 2019, 05:48:39 PM »
Thank you much fish head. I'm going to try this tomorrow morning
November 03, 2019, 07:28:33 PM
Bat21
Reply #9 on:
November 03, 2019, 07:28:33 PM »
i think i found a solution this weekend, im using a scraper to get most of the silicon off, then im using a 3m product called adhesive remover which softens the silicon then i wire brush it off, its alot of work and slow going but its working, ill keep posting my progress, hoping to be able to paint boat in 3 weeks. the silicon is from the rub rail i removed, somebody really packed it on behind it.
January 12, 2020, 11:43:23 AM
Bat21
Reply #10 on:
January 12, 2020, 11:43:23 AM »
Boat is all painted and all hardware installed. I'm really happy with the results. Almost finished with this project. Boat show in two weeks and I'm planning on purchasing a new sounder/fish finder then I can close the wiring channel on deck and I will send in pics for all to see
January 13, 2020, 08:36:53 AM
CTsalt12
Reply #11 on:
January 13, 2020, 08:36:53 AM »
Great news. Let's see some pictures and a bit more info about your process (aside from the silicone) and products used?
I'd like to tackle a interior paint job possibly this year if time allows so I'm curious.
Jimbo
1989 175 Osprey
June 05, 2020, 03:29:58 PM
thill
Reply #12 on:
June 05, 2020, 03:29:58 PM »
Denatured Alcohol helps soften and release silicone residue. Then rub vigorously with a dry cloth, and it will usually come right off without damage
-TH
