Author Topic: Where to get a fuel tank  (Read 1211 times)
October 13, 2019, 08:50:35 PM
Read 1211 times
nismokat
« on: October 13, 2019, 08:50:35 PM »
Hey guys I’m restoring my Osprey 170. Does anyone know where I can get a fuel tank from? I’m waiting to hear back from a few places to have one made. I figure I try here also maybe someone can guide me the right direction.
October 13, 2019, 11:44:15 PM
boatnamesue
  • Jason
Re: Where to get a fuel tank
« Reply #1 on: October 13, 2019, 11:44:15 PM »
Your options will depend on the tank dimensions for your hull.  Reply with your model year hull and I’m sure a member will reply with the specs.
If the Osprey 170 tank dimensions are same as the mid 70’s 170 tanks then poly won’t be an option.  You’ll need a custom built Aluminum tank bc of the short height, which is like 5.5” if I remember correctly.
Jason
1976 AS 170
1998 S115TLRW
October 14, 2019, 06:55:22 AM
« Reply #2 on: October 14, 2019, 06:55:22 AM »
Start here:
https://classicaquasport.com/smf/index.php?topic=11420.msg113572#msg113572
Then contact:
http://marinefueltanks.name/6501/index.html
Or, depending on location:
http://www.rdsaluminum.com/
Both have built fuel tanks for Aquasport while it was in production. Phil at Alloy Metal has made quite a few for members here as has RDS (They made my 1991 replacement).
October 14, 2019, 11:48:49 PM
nismokat
« Reply #3 on: October 14, 2019, 11:48:49 PM »
If I measure correctly I got 58” long , 21” wide and 8” y’all. This is 87 Osprey 170
October 15, 2019, 06:58:07 AM
« Reply #4 on: October 15, 2019, 06:58:07 AM »
170 Ospreys came from the factory with a 27 gallon fuel tank.
Your tank measurements equates to a 42 gallon tank. Maybe the PO changed it out some time ago. Can you make out the tank manufacturer spec sticker on the top of the tank?
Florida Marine (FMT) supplied Hialeah hulls with tanks. My 84 CCP as well as my 91 WAC (Bradenton plant) were both originally equipped with FMT tanks.
Good luck. :thumright:
October 15, 2019, 11:42:45 PM
boatnamesue
  • Jason
« Reply #5 on: October 15, 2019, 11:42:45 PM »
Where you located?
Jason
1976 AS 170
1998 S115TLRW
November 06, 2019, 09:36:03 PM
nismokat
« Reply #6 on: November 06, 2019, 09:36:03 PM »
Port Saint Lucie , FL I’m actually getting an aluminum tank build at the moment.
