Author Topic: Starter relay/selenoid  (Read 468 times)
September 29, 2019, 08:37:44 PM
Read 468 times
Oyster toad
« on: September 29, 2019, 08:37:44 PM »
Hi out there need some help please i have a 1985 Yamaha 150hp on 1979 200ccp  my service manual says to disconnect the starter relay/solenoid to test so I did it says there should be no continuity between black/grind wire and brown ignition wire but there is so I hooked 12v to it and it works fine but when I put it on motor I have no tilt/trim and ignition sometimes don T work my issue is other adenoids are supposed to have continuity why not this one and is this causing my problem the starter and trim solenoid are all hooked together and trim works without starter one any answers would be awesome thanks
