Author Topic: Osprey 200 Inner hull finish  (Read 603 times)
September 19, 2019, 10:51:50 PM
Read 603 times
Jlcalzada
« on: September 19, 2019, 10:51:50 PM »
Need some help. Cleaning up a 1998 Osprey 200, should the interior of the hull achieve a glossy finish like the exterior? It was chalky and got it very  lean and smooth but not glossy.
September 20, 2019, 07:06:45 AM
Re: Osprey 200 Inner hull finish
« Reply #1 on: September 20, 2019, 07:06:45 AM »
Sounds like typical old gelcoat.  Might need to compound it to get it shiny.
September 20, 2019, 07:23:23 AM
« Reply #2 on: September 20, 2019, 07:23:23 AM »
Try this:
https://www.prestaproducts.com/Ultra_Cutting_Creme-details.aspx
And for additional gloss, finish with this:
https://www.prestaproducts.com/Ultra_Polish__Chroma_1500-details.aspx
Then apply your favorite wax. I've found that the Cutting Creme works great by itself on all but the heaviest oxidation. For that use this:
https://www.prestaproducts.com/Gel_Coat_Compound-details.aspx
This is an older photo but taken shortly after buffing with the Cutting Creme.
That's 28 year old gel coat.
Good luck. :thumright:
PS....Once you got her all shiney, clean up the blood and guts with this stuff. Works very well.
https://www.prestaproducts.com/Marine_Hull___Deck_Cleaner-details.aspx
September 20, 2019, 05:49:01 PM
Jlcalzada
« Reply #3 on: September 20, 2019, 05:49:01 PM »
Thank you gentlemen. I'll try the cutting cream and polish on a small Area first. If we don't achieve the desired results we'll resort to the  cutting compound.
