Author Topic: Instructions and Materials For Filling Deck Hole  (Read 987 times)
August 27, 2019, 12:46:04 AM
Read 987 times
boatnamesue
  • Jason
« on: August 27, 2019, 12:46:04 AM »
1976 170
Replacing my bow mounted trolling motor w/new model.  It's possible the hole configuration of my current mount will not align with the new mount.  Just in case it doesn't, or it does but I want/need to reposition the new mount, I'd like one of y'all builders to detail the appropriate method for filling holes.
I believe the through holes (4) are 1/4" or 3/8" diameter.  Recommended materials and method of use would be great.  Many thanks.
Jason
1976 AS 170
1998 S115TLRW
August 27, 2019, 02:05:00 AM
theFunsmith
Re: Instructions and Materials For Filling Deck Hole
« Reply #1 on: August 27, 2019, 02:05:00 AM »
I have learned a whole lot from Andy at Boatworks Today. This video gave me guidance to fill quite a few holes in my boat. Because the holes that you have will be around mounting holes for the new motor, and therefore will bear some load, I think it is good to err on the side of caution and fill as strongly as possible. Whether or not you use this method, this is just good information to have.
August 28, 2019, 01:04:31 AM
boatnamesue
  • Jason
« Reply #2 on: August 28, 2019, 01:04:31 AM »
I'll take a look, thanks!
Jason
1976 AS 170
1998 S115TLRW
August 28, 2019, 07:16:48 AM
Mwar410
« Reply #3 on: August 28, 2019, 07:16:48 AM »
 Drilled holes are a little different from bullet holes, there's not typically much de lamination. That would be quite a repair for a few drilled holes.
I always open the hole up with a countersink
wet out with whatever resin I'm using, poly or epoxy
then pack with thickened resin , usually thick enough I don't have to back it with tape. Keeping it small enough not to damage too much non skid while sanding
Seal it with paint or gel coat to match.
1978 "170" 91' Yamaha 90hp
Mike
September 03, 2019, 12:30:15 AM
boatnamesue
  • Jason
« Reply #4 on: September 03, 2019, 12:30:15 AM »
Haven't been able to get over to boat with this storm baring down on us FL folk.  Need to see if the new motor mounting plate holes line up with the old.  I can confirm the 4 holes are 2" x 1/4".
So if I do need to drill new holes, thoughts on plugging old holes and using the west system injectable epoxy?  I reckon cuz the holes are small diameter, the delivery method has got to be injectable....otherwise air pockets.  Right?
Jason
1976 AS 170
1998 S115TLRW
September 03, 2019, 08:09:11 AM
« Reply #5 on: September 03, 2019, 08:09:11 AM »
Yes, injecting is probably the best way to fill, but you don’t need to go with West.  You can use grout bags, pastry bags or even a zip lock with 1 corner cut off to squeeze it into the hole.  Cabosil thickened epoxy will work fine and you can mix your own.  I recommend countersinking both ends of the hole, so the plug will have a barbell shape to lock it in place.  Put tape on 1 end.  Poke a small hole in the tape to allow air to escape, and fill with thickened epoxy.
September 04, 2019, 12:45:39 AM
boatnamesue
  • Jason
« Reply #6 on: September 04, 2019, 12:45:39 AM »
Awesome shugg, thanks.
Jason
1976 AS 170
1998 S115TLRW
