Author Topic: 1969 flatback rebuild  (Read 2449 times)
August 17, 2019, 08:46:12 AM
Read 2449 times
Robert
« on: August 17, 2019, 08:46:12 AM »
After looking at the other rebuilds for a long time I am ready to start mine. I have a 69 22-2 that my dad bought new at Gasparilla Marina 50 years ago. I have been through a bunch of boats since then but held on to the 22-2 all these years. It is a boat I fished in with my parents and grandparents, I know have grown children of my own. It is time. I will be posting pics and seeking input as I go, advice is much appreciated. Thank you to all who have done their projects already, I have dozens of screen shots and pages and pages of notes based on your work. Rob
August 17, 2019, 03:27:33 PM
Re: 1969 flatback rebuild
« Reply #1 on: August 17, 2019, 03:27:33 PM »
Welcome Aboard Robert.  Good luck on the rebuild and we'll be here whenever you have a question.
August 17, 2019, 07:03:38 PM
Robert
« Reply #2 on: August 17, 2019, 07:03:38 PM »
Thanks Rick, here are some photos over the last few weeks, getting started.
August 17, 2019, 07:07:07 PM
Robert
« Reply #3 on: August 17, 2019, 07:07:07 PM »
Then starting on the stringers. This is going to be a total redo, There was one cracked stringer on the starboard side but other than that they were in good shape for a 50 year old boat.
August 18, 2019, 06:35:21 AM
« Reply #4 on: August 18, 2019, 06:35:21 AM »
Robert, if you want to post a pic when you talk about your boat, which you should, follow the instructions here http://classicaquasport.com/smf/index.php?topic=12725.0  - don't attach them, this is better for viewing and you won't be limited by size.
Spend a few minutes to absorb the instructions. It's really easy.
August 18, 2019, 03:04:37 PM
Robert
« Reply #5 on: August 18, 2019, 03:04:37 PM »
Ahh, I will work on that right now. Thanks
August 18, 2019, 03:43:30 PM
Robert
« Reply #6 on: August 18, 2019, 03:43:30 PM »
Here are some pics of the transom removal. I wanted to leave as much of the old outer skin as possible and clamp new material to it with wet glass in between. I cut around the edges with the sawsall and multi tool, I cut some long PT wedges and drove them in between the wood and outer glass. Once they separated I cut the transom up into 3 pieces, much heavier than I expected, I don't believe the new coosa transom will be as heavy even though it will be taller.
August 18, 2019, 03:47:32 PM
Robert
« Reply #7 on: August 18, 2019, 03:47:32 PM »
Going to do a little more grinding, pressure wash it and take it to the sandblaster to etch the inside a little. This is where I am today. Sorry for the small pictures, I can't follow the steps on my iPad. Will have to get on my office computer to fix.
August 18, 2019, 03:50:13 PM
Robert
« Reply #8 on: August 18, 2019, 03:50:13 PM »
My plan is once I get the boat sandblasted I am going to put in the new coosa transom. After that install one layer of 1708 on the entire bottom of the boat and up the sides to the height of the new floor. Then start fitting stringers.
August 18, 2019, 04:02:40 PM
« Reply #9 on: August 18, 2019, 04:02:40 PM »
It’s so cool that your giving new life to a family legacy.  Do you have plans to keep the boat square while your doing the transom and stringers?
August 18, 2019, 06:41:45 PM
« Reply #10 on: August 18, 2019, 06:41:45 PM »
Cool boat, and awesome that it was your dad's. Looking forward to watching the build. We were at Eldred's today right around the corner from the Gasparilla marina. Good luck!
August 18, 2019, 06:58:26 PM
Robert
« Reply #11 on: August 18, 2019, 06:58:26 PM »
I am going to leave the hull on the trailer to do the work. My plan is to block the trailer flat and level then brace the boat off both the ground and the trailer. For being as old as it is it was pretty true before I started cutting. No visible hook in the bottom but I am not going to block it until I get if back from the sandblaster. Ironically getting it sandblasted at Gasparila Marina the same place it was sold new, Chris at Gasparilla Marine Services is taking care of that. Thanks Mike, it will be fun!
September 03, 2019, 03:33:21 PM
Robert
« Reply #12 on: September 03, 2019, 03:33:21 PM »
Been busy but got the hull to Gasparilla to have the interior sandblasted, well worth the money. Inside is clean and ready to accept glass.
September 03, 2019, 05:10:27 PM
« Reply #13 on: September 03, 2019, 05:10:27 PM »
Definitely the easy way
September 03, 2019, 08:13:25 PM
« Reply #14 on: September 03, 2019, 08:13:25 PM »
Better than spending the hottest part of the year grinding glass. I know!
