222 CCP Rebuilds
222 CCP newbie rebiuld deck hull joint questions
Topic: 222 CCP newbie rebiuld deck hull joint questions (Read 673 times)
August 10, 2019, 04:25:51 PM
Read 673 times
jjourdan23
August 10, 2019, 04:25:51 PM »
Hello, I was just given an 86 222 CCP. I am new to all of this but have been researching the rebuilds for a while now. I have a problem area on the deck hull joint and was looking for advice on the best way to handle it. Any advice would be greatly appreciated.
August 10, 2019, 04:27:43 PM
jjourdan23
Re: 222 CCP newbie rebiuld deck hull joint questions
August 10, 2019, 04:27:43 PM »
As you can see it looks like someone tried to fix a damaged area with some kind of filler.
August 10, 2019, 07:38:07 PM
August 10, 2019, 07:38:07 PM »
That's weird, never seen that - not a fiber board like they use on roofs, but not a piece of solid wood either. I think the entire length is the same - maybe a Friday boat ? Mine was a solid wood, maybe oak?
August 10, 2019, 08:17:21 PM
August 10, 2019, 08:17:21 PM »
Instead of attaching pics, which are "size" limited, try uploading them to your free gallery.
If you want to post a pic when you talk about your boat, which you should, follow the instructions here
http://classicaquasport.com/smf/index.php?topic=12725.0
- don't attach them, this is better for viewing.
Spend a few minutes to absorb the instructions. It's really easy.
222 CCP Rebuilds
