Electrical
Wiring nav lights on a 170
Topic: Wiring nav lights on a 170 (Read 1126 times)
July 11, 2019, 07:31:50 AM
Read 1126 times
outboardsurplus
July 11, 2019, 07:31:50 AM »
Just got this and was wondering how to wire in new front and back lights and the running new wires for them.
July 11, 2019, 07:34:53 AM
Global Moderator
Re: Wiring nav lights on a 170
July 11, 2019, 07:34:53 AM »
Light reading.
https://classicaquasport.com/smf/index.php?topic=15074.0
July 11, 2019, 12:19:12 PM
Mwar410
July 11, 2019, 12:19:12 PM »
I was able to fish them from the fuel coffin to the starboard bow locker pretty easily. Drilled a hole along side the filler hose and ran them in 1 1/8" bilge hose to prevent chafing. I used fiberglass fish sticks and was able to guide it through the starboard casting deck locker (deck plate). Pulled 2 duplex for lights and 2 speaker wires.
1978 "170" 91' Yamaha 90hp
Mike
July 11, 2019, 02:02:19 PM
outboardsurplus
July 11, 2019, 02:02:19 PM »
Thanks for the help,will give it a shot
July 11, 2019, 04:09:13 PM
Mwar410
July 11, 2019, 04:09:13 PM »
If this helps more. Actually ran the wires first, then pushed the hose over them from the coffin.
Because every Aquasport Ned's some of these
Mike
July 11, 2019, 04:12:12 PM
outboardsurplus
July 11, 2019, 04:12:12 PM »
Good idea,thanks
July 11, 2019, 10:35:30 PM
boatnamesue
Jason
July 11, 2019, 10:35:30 PM »
Agreed!
Jason
1976 AS 170
1998 S115TLRW
July 12, 2019, 04:47:03 PM
July 12, 2019, 04:47:03 PM »
Make sure you look at the regs before you install those shark eyes - they have to be installed properly, usually above the sheer IIRC, to be legal - if you get a Wildlife Officer having a bad day, it could be bad for you. We've had a discussion on this before on the site - maybe our master searcher, CB can find it.
Here are the regs:
https://www.boatsafe.com/nauticalknowhow/sidelights/
The confusion is in the definition of being "above the deck". Good luck.
Here is a thread on this topic from THT -
https://www.thehulltruth.com/boating-forum/313132-shark-eye-navigational-lighting-fines-2.html
July 12, 2019, 07:32:07 PM
Mwar410
July 12, 2019, 07:32:07 PM »
Well that really kinda stinks .
Mike
July 12, 2019, 07:53:10 PM
Reply #9 on:
July 12, 2019, 07:53:10 PM »
Yup. You can be an outlaw and hope you don't get pulled over, don't go out at night, or maybe get popup nav lights. I bought a Livorsi popup so I could store it out of the way when not traveling at night and wanting to use a trolling motor across that area.
https://www.google.com/search?client=firefox-b-1-d&ei=IB0pXerlA8iO5wK49pSgCw&q=livorsi+marine+popup+navigation+lights&oq=livorsi+marine+popup+navigation+lights&gs_l=psy-ab.3...19887.22285..23920...0.0..0.113.562.5j1....2..0....1..gws-wiz.......0i71j0i30j0i333.aaJTtcFKtdM
July 12, 2019, 09:54:21 PM
Global Moderator
Reply #10 on:
July 12, 2019, 09:54:21 PM »
This is the one I remember from awhile back.
https://classicaquasport.com/smf/index.php?topic=8738.0
July 13, 2019, 12:12:11 AM
boatnamesue
Jason
Reply #11 on:
July 13, 2019, 12:12:11 AM »
I believe reg is 120°. FWC is looking for the obvious violation to this reg, or at least in my area (words taken directly from a FWC officer). So you have to really screw up the distance btwn lights to catch their attention. And that's assuming you're boarded by a pissed off officer whom is carrying a protractor.
Jason
1976 AS 170
1998 S115TLRW
Electrical
