165/170/175 Rebuilds
Transom material
Topic: Transom material (Read 1144 times)
July 02, 2019, 06:19:02 PM
Read 1144 times
mtgtool
Transom material
July 02, 2019, 06:19:02 PM »
Hello to all, my name is Mike. I need a little information please. I bought a 2000 Osprey AquaSport 175. Brought home and started work on it. I've taken the cap off, stringers were delaminated so I completely cleaned and sanded. I am ready to apoxy, but looking at transom it looks like a synthetic core material - it has been wet. It is black although it seems solid. Wandering what it was made of and if anyone has info on what the material is.
Please let me know any information you may have. Thank you
July 03, 2019, 06:53:32 AM
Re: Transom material
July 03, 2019, 06:53:32 AM »
In that year they were pouring the transoms with a composite material. Should be impervious to water.
July 03, 2019, 12:12:29 PM
July 03, 2019, 12:12:29 PM »
Poured ceramic composite. Usually it's white or very light gray. You can always drill a small test hole into it in a non vital spot to see what you have.
July 03, 2019, 08:32:35 PM
mtgtool
July 03, 2019, 08:32:35 PM »
Thank you for the responses. It doesn't appear to be poured. It looks like 2 sheets of synthetic material. I just didn't want to put it back together and later find out I had a problem. It does seem to be solid. I'll post a picture for you to look at. Appreciate the help and have a happy, safe 4th of July.
July 05, 2019, 05:17:47 PM
Global Moderator
July 05, 2019, 05:17:47 PM »
Interesting
Now you should get a response.
July 05, 2019, 06:32:22 PM
July 05, 2019, 06:32:22 PM »
Kinda looks like two sheets of coosa board.
July 06, 2019, 08:28:32 AM
Global Moderator
July 06, 2019, 08:28:32 AM »
While it isn't a "poured material" it appears to be factory. We've been told by a member that worked at the plant that in an effort to keep pace with assembly, if they ran short on composite pouring media, they would substitute coring material with what was on hand. I'd guess this is what you're looking at with your hull.
As Wing stated, you may wish to core an area to check but looking at the photo, I would think the old "bang with a mallet" test over the transom surface will tell you what you need to know.
It looks good from here if that's any help.
July 06, 2019, 10:03:33 AM
mtgtool
July 06, 2019, 10:03:33 AM »
Thank you Captain Bob for helping me with pic info and for the info I was looking for. Transom seems to be solid and was a bit worried not knowing what it was.
Appreciation to all.
July 07, 2019, 08:45:10 PM
mtgtool
July 07, 2019, 08:45:10 PM »
I am back and have a new problem. I found some rotten wood inside the stringers. The wood was held by a couple of screws in side the stringer and foamed in. Doesn't appear to have any structural value to me. I cut it all out and don't see a need to put it back, but I don't know. I was going to apoxy with some 1708 and foam over it. Please advise any thoughts or what else can be done. I have some pictures. Thank you all.
Captain Bob I could use your help again with photos. I've uploaded to my gallery, cannot get them attached. Please help.
July 08, 2019, 05:14:08 AM
Reply #9 on:
July 08, 2019, 05:14:08 AM »
If you have your pix in your album you've done the hard part - follow the instructions in this link to post them in your topic
https://classicaquasport.com/smf/index.php?topic=12725.0
As for the wood - you don't need any wood in the stringers.
Transom material
