Author Topic: 74 Proline 24  (Read 3047 times)
July 01, 2019, 12:19:40 PM
dirtwheelsfl
Re: 74 Proline 24
« Reply #15 on: July 01, 2019, 12:19:40 PM »
You want the keel, chines and stern corners all supported. 2x10x12ft “bunks” under the chines conforming to the hull is where id start. Maybe put another under the keel on edge. Use the eyecrometer and some diagonal measurements and maybe pull a few criss cross intersecting strings to make sure shes true before adding structure back. You can shim with some thin plywood where needed
July 01, 2019, 02:51:05 PM
Re: 74 Proline 24
« Reply #16 on: July 01, 2019, 02:51:05 PM »
“Eyecrometer”. I like that. :1rij:
July 01, 2019, 08:52:04 PM
Re: 74 Proline 24
« Reply #17 on: July 01, 2019, 08:52:04 PM »
Sometimes better than a level  :thumleft:
July 02, 2019, 01:59:27 AM
McAllgeyver
Re: 74 Proline 24
« Reply #18 on: July 02, 2019, 01:59:27 AM »
And just think... if you don't like the first eyecrometer reading, use your other eyecrometer.  :57:
Sean A.
1975 Banana River Skiff - rebuilt - SOLD
1973 19-6 Osprey - rebuilt
July 02, 2019, 07:51:14 AM
dirtwheelsfl
Re: 74 Proline 24
« Reply #19 on: July 02, 2019, 07:51:14 AM »
It usually doesnt lie!   Depends on your vision i guess...  I typically stand in front of the boat and just line up intersecting reference points starting at the top of the stem. Shim or adjust stands as needed.
