Aquasport Discussion
86 22-2 ccp
Topic: 86 22-2 ccp (Read 389 times)
January 07, 2019, 10:02:17 AM
Read 389 times
Nothinyet
86 22-2 ccp
January 07, 2019, 10:02:17 AM »
I recently bought an 1986 222ccp. I want to add some aluminum rails for rod holders and downriggers. The ones i ordered are 60 lond and 4 in wide. Planning on putting them on each gunwale from transom forwards. Can i remove the caps to install them and add support to the bottom of the caps for stability? They look to be removable. Any ideas? Thanks in advance .
January 07, 2019, 11:27:30 AM
Mechanical Master
Re: 86 22-2 ccp
January 07, 2019, 11:27:30 AM »
The gunnel caps on each side toward the stern are removable, but they also hold the rod holders in place.
January 08, 2019, 10:21:32 AM
Nothinyet
Re: 86 22-2 ccp
January 08, 2019, 10:21:32 AM »
Ok, thanks. Any idea what type of sealant to use when i replace them? Looks like white silicone.
January 09, 2019, 08:48:25 AM
Re: 86 22-2 ccp
January 09, 2019, 08:48:25 AM »
Quote from: Nothinyet on January 08, 2019, 10:21:32 AM
I’d use 3M UV 4000. It’s a great sealer with some adhesive properties, but not so much you can’t get it apart later. Since your downriggers will put some some stress on the covering boards, I suggest using through bolts with fender washers everywhere you can get to the back side.
January 09, 2019, 07:41:55 PM
Nothinyet
Re: 86 22-2 ccp
January 09, 2019, 07:41:55 PM »
Sounds good. As for the fender washers, im goimg a step further and i am going to put an aluminum plate that will run the full length of the cisco track system i purchased. And i will orders some the 3m sealant you reccomended. Thanks!
86 22-2 ccp
