Author Topic: Motor Upgrade?  (Read 901 times)
December 28, 2018, 08:36:09 PM
Read 901 times
Bencarpenter112
Motor Upgrade?
« on: December 28, 2018, 08:36:09 PM »
I currently have a osprey 200 1987 that is in the process of being rebuilt. Found a great deal on enough coosa for the floors and transom so I have some reduced weight there. Floors are raised three inches as well to get the scuppers above the waterline. I also refoamed the sides and removed about 250 lbs of weight foam. Reason Im posting here is because I have the mercury 115 carborated 2 stroke. I also have a tower and 35 gallon live well. Prior to the floor and transom change plus the wet floors my WOT was 31mph with 2 people and 20 gallons of fuel. Im wondering if the 115 is gonna be enough before mounting it or if im in need of a larger hp motor. Boat is used inshore primarily other than the runs to 7 and 12 miles out of egmont key florida. Could be propped wrong? not sure looking for advice
1988 Aquasport Osprey 200
1987 Mako 17 (Sold)
1996 Palm Beach 18 Skiff (Sold)
December 28, 2018, 08:37:10 PM
Bencarpenter112
Re: Motor Upgrade?
« Reply #1 on: December 28, 2018, 08:37:10 PM »
Transom is also closed now  for reference.
1987 Mako 17 (Sold)
December 29, 2018, 06:21:21 AM
Re: Motor Upgrade?
« Reply #2 on: December 29, 2018, 06:21:21 AM »
I don't think that a 115 is enough power for a 200 Osprey.  Max HP is 185 for that model, so I would think a 150 is about right.
Are you putting a jack plate, swim platform or bracket to get the engine back a little so you can tilt it, since you've closed in the transom?
December 29, 2018, 07:35:52 AM
Re: Motor Upgrade?
« Reply #3 on: December 29, 2018, 07:35:52 AM »
As Rick said, the 115 is marginal for a 200 Osprey.  Most were rigged with a 150.
 Even so, 31 sounds slow even for a 115.  What RPM were you turning at max speed?  Max RPM for your motor is probably in the 5000-6000 range. Check to be sure   If you’re not somewhere in that range, you need a different prop.  For max economy, you probably want to cruise at 25 mph in the 3500-4000 RPM range.
You’ll loose some weight with the coosa, but most builders add a bit more glass here and there.  So there may not be much weight difference between stock.
December 30, 2018, 01:17:12 PM
Bencarpenter112
Re: Motor Upgrade?
« Reply #4 on: December 30, 2018, 01:17:12 PM »
Yes it will be getting a 12 or 14 inch set back plate from bobs. I was thinking 150 or 140 is appropriate. the 115 WOT is around 5200-5400 rpm. It is fitted with a tower as well. I thought it was a bit low also so I repropped from general propellers. Buddy of mine has a 135 opti with a four blade on the same boat and gets about 35 out of it but much better hole shot and he also has a large top. Seems 150 is the answer to get into the 40's which would only be done in emergency but I would like to take my cruising speed to about 28-30 instead of 22-25 depending on load.
1987 Mako 17 (Sold)
December 31, 2018, 12:15:40 AM
boatnamesue
  • Jason
Re: Motor Upgrade?
« Reply #5 on: December 31, 2018, 12:15:40 AM »
As mshugg mentioned, knowing if your engine is able to reach top of rpm range at WOT is more important than using top speed as a measure of engine performance.  And of course if the prop isn't dialed in this will skew performance.
With that said, I believe top end of 31mph is pretty darn close to what I'd expect a 115hp to push your hull.  I'm using my 2 stroke 115hp on my 170 as the reference.  My rig is significantly lighter, dialed in prop, and I top out mid 40s.
If you can afford a bigger engine I'd definitely step up to minimum 150hp.  You'll be adding 100+ lbs but you'll rig overall will perform better.  Good luck.
Jason
1976 AS 170
1998 S115TLRW
January 13, 2019, 04:51:34 PM
Dano
Re: Motor Upgrade?
« Reply #6 on: January 13, 2019, 04:51:34 PM »
I have an 04 Osprey 200 with a Yamaha F115 with a 3 blade 17p prop. I cruise at 30-31 @42-4400 rpms and top out at about 39 with a light load. The boat has a T-Top also.
Fully loaded with 3 guys, ice 1/2 tank fuel and forward bait well going I get the same cruise but top speed is down to about 35ish. Wish someone made a 150hp 4 stroke that only weighed 400lbs.
January 13, 2019, 05:13:10 PM
Re: Motor Upgrade?
« Reply #7 on: January 13, 2019, 05:13:10 PM »
The Mercury Four Stroke 150 is only 455 in 20” shaft.  Would be perfect for an Osprey 200.
January 13, 2019, 05:55:45 PM
Dano
Re: Motor Upgrade?
« Reply #8 on: January 13, 2019, 05:55:45 PM »
Hard to find out the weight in a 25” model. I’ve heard good stuff about the new Merc.
Yamaha is in the 490 range for the 25”. I don’t want anymore weight back there than the 115...... just a little more power.
January 14, 2019, 07:08:46 PM
Re: Motor Upgrade?
« Reply #9 on: January 14, 2019, 07:08:46 PM »
Mercury 150 four cylinder  fourstroke is the way to go.  Blueagavehas one on his 19-6 with a full tower and bracket. Pushes it great. He runsaid all around Tampa Bay with it.
January 14, 2019, 07:31:22 PM
Re: Motor Upgrade?
« Reply #10 on: January 14, 2019, 07:31:22 PM »
Weight on the 25” is 465.  It’s the lightest 150 available.
January 21, 2019, 02:44:01 PM
Bencarpenter112
Re: Motor Upgrade?
« Reply #11 on: January 21, 2019, 02:44:01 PM »
150 seems to be the right answer here and it would seem the suzuki 175 would be overkill even though they do weigh the same. buddy of mine runs a 135 opti and he seems to do alright with it which pushes me north of the 140 as well. Thanks for all the opinions. My deck has been rised now 3 inches and the transom closed. Everything done in coosa and epoxy. still have to weigh her but hopefully a good bit lighter
1987 Mako 17 (Sold)
January 28, 2019, 10:40:02 AM
Aquasport17
Re: Motor Upgrade?
« Reply #12 on: January 28, 2019, 10:40:02 AM »
Well I just got this 170. Have an old boat with 85hp jonhson.  Have a guy that might want to trade old boat for susaski 115hp 2 stroke it might be short shaft. He checking that later.  Is the motor a good trade. Heard good and bad things about them. Plus not if short shaft will work with my hull ok.
January 28, 2019, 11:31:14 PM
boatnamesue
  • Jason
Re: Motor Upgrade?
« Reply #13 on: January 28, 2019, 11:31:14 PM »
What you've heard is expected, really, because the answer to your question is completely subjective.  I don't expect too many objections from this statement, so here goes....maintanance, maintanance, maintanance.  That's the end all be all when considering a used motor, no matter the brand.  Personally I'm a yamaha guy, always been.  With that said, I'll take a meticulously maintained suki, rude, you name it, over a poorly maintained yamaha everyday.  Find a well maintained 2 stroke, continue to maintain it, and it will run like a beast till forever.
Jason
1976 AS 170
1998 S115TLRW
