Aquasport Discussion
Pros / Cons 20" Shaft motor on a 222 FB
Topic: Pros / Cons 20" Shaft motor on a 222 FB (Read 372 times)
September 25, 2018, 07:23:17 AM
Read 372 times
steveiguess
September 25, 2018, 07:23:17 AM »
Just researching the topic and wondering if there are any pros/cons to putting a 20" shaft motor on a flatback with a portabracket.
Thank you for your opinions/insight
September 25, 2018, 12:22:41 PM
Re: Pros / Cons 20" Shaft motor on a 222 FB
September 25, 2018, 12:22:41 PM »
Cannot think of any pros. The one glaring con is that your powerhead is five inches closer to the water. With the motor on the bracket, when coming off plane, water will have the opportunity to enter the cowling.
September 25, 2018, 04:50:13 PM
September 25, 2018, 04:50:13 PM »
I agree with Blue on this. There is no advantage of a 20” shaft on a sea boat. The shorter shaft puts the powerhead and exhaust passages closer to the water. There’s even a potential of powehead failure if you suck water I to the exhaust relief.
September 28, 2018, 09:08:07 PM
Mechanical Master
September 28, 2018, 09:08:07 PM »
Your outboard needs to be as high a possible on the transom:
https://www.facebook.com/midwestmarinewa/videos/1924176464295600/?t=7
