Gallery
Gallery
Engines & engine woes
Dings on Head?
Topic: Dings on Head? (Read 510 times)
July 31, 2018, 09:25:43 AM
Read 510 times
Mechanical Master
Dings on Head?
July 31, 2018, 09:25:43 AM »
I finally got around to tearing into the old 2.4L Merc - very happy with the new Optimax, but was wondering what killed the old mota...
I took both heads off - one cylinder head shows where some metal got in there and dinged up the head - same stuff on the top of the piston. So where do y'all think it came from? The other 5 cylinders are clean as a whistle. Ideas?
July 31, 2018, 10:55:07 AM
FL.flatback
Re: Dings on Head?
July 31, 2018, 10:55:07 AM »
Piece of reed valves?
July 31, 2018, 12:12:04 PM
Global Moderator
Re: Dings on Head?
July 31, 2018, 12:12:04 PM »
Piston ring?
July 31, 2018, 06:30:49 PM
Re: Dings on Head?
July 31, 2018, 06:30:49 PM »
Where is our buddy Farley?
July 31, 2018, 07:34:51 PM
Mechanical Master
Re: Dings on Head?
July 31, 2018, 07:34:51 PM »
I mentioned to John,
Broken ring segments
Broken reed petal segments
Broken bearing pieces or race.
August 01, 2018, 06:32:16 PM
Re: Dings on Head?
August 01, 2018, 06:32:16 PM »
How do the cylinder walls look? Edges of the intake and exhaust ports?
August 03, 2018, 10:58:06 AM
Mechanical Master
Re: Dings on Head?
August 03, 2018, 10:58:06 AM »
Quote from: wingtime on August 01, 2018, 06:32:16 PM
Cylinder looks good and no damage to ports. It just looks like something got sucked into the cylinder and banged around a bit. The top of the piston has marks like the head from contact, but the cylinder wall looks fine.
My next move is to take the carbs and front end off and see what the reeds look like. I'm thinking a broken reed, but who knows?
August 03, 2018, 11:31:57 AM
jdupree
Re: Dings on Head?
August 03, 2018, 11:31:57 AM »
I can't remember, did it still run when you took it off? It will be interesting to see what you find. Throw a new piston and rings in it and sell it
John L. Dupree, III
AQABLA84E999
Member #257
August 03, 2018, 07:05:07 PM
Re: Dings on Head?
August 03, 2018, 07:05:07 PM »
If it just a broken reed that would be awesome. I'd pull that piston, inspect the cylinder rings etc. Throw in a set of Chris Carson Reeds and sell that baby.
Keep in mind I can get you engine parts, gaskets etc at a discount for members.
Dings on Head?
