Electronics
Wire Fasteners/Organization
Topic: Wire Fasteners/Organization (Read 1172 times)
July 25, 2018, 05:42:22 PM
Read 1172 times
CTsalt12
July 25, 2018, 05:42:22 PM »
Hi All,
I'm trying to organize the wiring inside my console. End result is I want it neat and all wires routed on the outside of the console, out of the way, and secure, and I'm trying to determine the best way to do it.
What I have now are nylon cable clamps, something like this:
https://www.waytekwire.com/products/1378/Nylon-Cable-Clamps/
This requires presumably screwing these clamps into the console. I'd prefer not to drill a whole much of screws into my console and risk spider cracks, etc. It really seems this is what most consoles do though. I'm wondering what everyone else is doing? Epoxy starboard to then drill holes into, as opposed to fiberglass? Any creative ways to get there wire clamps to adhere to the inside of the console?
Jimbo
1989 175 Osprey
July 25, 2018, 05:46:29 PM
Re: Wire Fasteners/Organization
July 25, 2018, 05:46:29 PM »
Yeah you have to line it or glue blocks where you need to attach the wires as you route it.
July 25, 2018, 05:53:10 PM
July 25, 2018, 05:53:10 PM »
If you use Starboard don’t use epoxy to glue it in place. Epoxy will hold for a while, but it won’t stick to the Starboard for long. 5200 works well enough, but you should rough up the back of the Starboard or even add saw kerfs. You will also need to tape the pieces in place until the 5200 cures.
You could also use pvc strips. Even the home store stuff will work,and epoxy bonds it quite well. Painted strips of wood will work too.
July 26, 2018, 06:42:47 PM
July 26, 2018, 06:42:47 PM »
Mount some pvc board inside the console and mount everything to that. Starboard is way overkill, expensive and heavy. You can get pvc board at home depot.
February 06, 2019, 03:07:33 PM
Bencarpenter112
February 06, 2019, 03:07:33 PM »
Quote from: RickK on July 25, 2018, 05:46:29 PM
Rick here has what seems to be the easiest way at least in the three that I have done. I did core my sidewalls for charger and radio amp to screw into but gluing the zip tie blocks saves time and weight and you can always go back and add more. If you put in to many than you can always not use them as they dont take up any space. They are also cheap which is a plus
1988 Aquasport Osprey 200
1987 Mako 17 (Sold)
1996 Palm Beach 18 Skiff (Sold)
April 15, 2019, 03:00:16 PM
CTsalt12
April 15, 2019, 03:00:16 PM »
Old thread, but I recently found some Ancor Adhesive zip tie mounts. Simply clean the area, stick the mounts to wherever I need a wire fastener and route the zip tie through. Different sizes for big zip ties for engine rigging and little guys for lights speakers etc.
https://www.westmarine.com/buy/ancor--self-adhesive-cable-tie-mounting-bases--P012030128
Easier than attaching a buffer and drilling fasteners, figured I'd share my solution.
Jimbo
1989 175 Osprey
Electronics
