Ran into my first "oh " moment of the build tonight. When I glassed in the drain pipe through the stringer, I didn't think to glass in the entire length of the pipe, I just did the ends where it came through. Well of course this meant that any water going in could leak out inside of the stringer into the foam. It also meant that any 2 part foam poured into the top of the stringer could leak into the pipe and drain out all over the bilge area! After a lot of cursing and plugging the drain hole with my finger to keep it clear, (yes that stuff gets hot!) I was able to scrape most of it up before it fully cured. So now I get to rethink my limber holes. In hindsite, I'm actually glad it happened now so I didn't end up with a bunch of soaked foam down the road. I hope you all get a good chuckle out of this and hopefully someone will read this and not make the same mistake!
