Author Topic: Mike's 77 22-2 Rebuild  (Read 31653 times)
April 28, 2019, 09:12:11 PM
Reply #255
perchman97
Re: Mike's 77 22-2 Rebuild
« Reply #255 on: April 28, 2019, 09:12:11 PM »
Boats really coming together nicely l!! Cap cane out sweet
April 29, 2019, 11:46:47 AM
Reply #256
« Reply #256 on: April 29, 2019, 11:46:47 AM »
Thanks guys. Not a lot of progress this weekend, just some sanding and prep for the next coat. Did manage to get out on the other boat for a few hours yesterday afternoon which was nice.
May 04, 2019, 05:28:37 PM
Reply #257
« Reply #257 on: May 04, 2019, 05:28:37 PM »
Fair, sand, repeat. Getting closer every day.
So question about fairing. How smooth is smooth enough being that I am going to gelcoat the inside? Is it better to get the surface 100% and then just sand the gelcoat enough to bring out the shine, or am I wasting a bunch of time trying to get it nice first?
May 05, 2019, 05:31:39 AM
Reply #258
« Reply #258 on: May 05, 2019, 05:31:39 AM »
You need to get the substrate kinda close = gelcoat fills a "fair" amount of blemishes/
I hope you are going to spray the gelcoat with a 50/50 mix with Duratec - that'll save you a bunch of effort trying to get a shine. I would think that most of the deck is going to be covered in nonskid minus the water runs, so that leaves the inside hull sides, gunwale sides and maybe the gunwale top (I would add places with nonskid on the gunwale top also) to be shiny. So if you you use the duratec you shouldn't have anything to shine up.
Was this your plan?
May 05, 2019, 05:37:49 AM
Reply #259
« Reply #259 on: May 05, 2019, 05:37:49 AM »
I'll check out the Duratec. I honestly haven't thought that far ahead yet. I guess I just figured I would roll it on and shine it up, but considering how long all this sanding takes it would definitely be worth a few extra bucks to save some time.
May 05, 2019, 05:42:20 AM
Reply #260
« Reply #260 on: May 05, 2019, 05:42:20 AM »
Get a cheap Harbor freight spray gun (I bought more expensive and they didn't work as well), learn how to take it apart to clean it quickly and you'll be fine. The Duratec is some great stuff.  Use it to spray your console too.
If you're going to have water runs (stripes in the deck for water to run off via) you want to spray them but the non-skid gelcoat is rolled on (I hope you use the nonskid approach I use - it is great result.
May 06, 2019, 08:54:58 PM
Reply #261
« Reply #261 on: May 06, 2019, 08:54:58 PM »
So I got a little sidetracked from fairing today and ended up buying a t-top. I've been eyeing it for months down at marine surplus and finally decided to just do it before it disappeared. It fits my console almost perfectly and I think it's a good size for the boat.
I will have to modify the hatch on the front and will lose the top door but I think it'll be pretty easy since I still have the fiberglass I cut out of it. I'll probably end up using it for the anchor locker hatch so it should work out fine.
I also think I may try to build a hardtop for it instead of canvas. I like that look a lot more, just not the price.
May 07, 2019, 04:04:49 AM
Reply #262
Woodeneye
« Reply #262 on: May 07, 2019, 04:04:49 AM »
Looks great. Wouldn't it be easier to cut and shut the support tubing? You must know someone that's a handy welder?
May 07, 2019, 06:32:43 AM
Reply #263
« Reply #263 on: May 07, 2019, 06:32:43 AM »
It’s easy to get side tracked from fairing.  Top looks great.
May 07, 2019, 07:14:37 AM
Reply #264
« Reply #264 on: May 07, 2019, 07:14:37 AM »
I did talk to a fabricator and it is doable of course, but we decided that repairing the fiberglass and modifying the hatch is the better way to go. Plus I do think those supports add to the overall look and will be helpful to hold onto when I add a cooler seat in the front. Oh, and the other big factor was that my spare time is worth a lot less than his.
May 07, 2019, 09:32:20 PM
Reply #265
« Reply #265 on: May 07, 2019, 09:32:20 PM »
Well thankfully I kept the cutout when I built the hatch originally so it was a simple fix. I cut it to size, glassed it back in from the backside, did a tiny bit of filling and fairing, and rolled some gelcoat on it. In total it only took about two hours. I will need to wet sand the gelcoat tomorrow but that should only take a few minutes. As for the starboard, it was just a matter of unscrewing the top piece and then cutting the sides down and drilling a few new holes across the top.
May 08, 2019, 05:41:14 AM
Reply #266
« Reply #266 on: May 08, 2019, 05:41:14 AM »
And then there is that way - looks good Mike.
May 08, 2019, 07:26:21 AM
Reply #267
Woodeneye
« Reply #267 on: May 08, 2019, 07:26:21 AM »
Keeping the cutout? Genius.
May 08, 2019, 09:38:10 AM
Reply #268
« Reply #268 on: May 08, 2019, 09:38:10 AM »
I think I have kept every scrap of glass, coosa and foam that I have cut lol. I could probably build a small skiff at this point out of all the crap laying around the shop.
May 19, 2019, 08:34:32 PM
Reply #269
« Reply #269 on: May 19, 2019, 08:34:32 PM »
I've been doing a lot of sanding and fairing lately. Just need to do a little more work on the hullsides and I can get ready to spray. I hosed all the dust off so I could get a good look at it and I think I'm about there.
HF has their spray guns on sale this week and I did some reading up on Duratech so it will hopefully go smoothly.
