Author Topic: 2001 26Ft Aquasport 250 Explorer 125 Gal Gas Tank measurements, anyone anyone  (Read 1350 times)
June 15, 2018, 04:42:41 PM
Read 1350 times
Ramtuff924
Mod Edit: Corrected original subject title.
Well gas tank took a crapper so going to have to replace it, its a 2011 Aquasport 250 Explorer, it says on the tank 125 gallon....anyone have any info on the size of the tank, going to have done in the fall, just figure I would look now..... before fall, I'd love to put in a "plastic tank" if at all possible.  Any assistance I would really appreciate it
June 15, 2018, 04:50:25 PM
jdupree
2011 250 Explorer??????  I think 2005 was the last year for the Explorer and the stock tank for the 250 Explorer was 141 gal.
John L. Dupree, III
AQABLA84E999
Member #257
June 15, 2018, 05:11:55 PM
Ramtuff924
My bad 2001   I have a 2011 car, my bad
June 15, 2018, 09:18:44 PM
Quote
The model you have is a 250 not a 26.5, they didn't include the anchor pulpit -so a 250 Explorer. I have a 230 Explorer that also has a pulpit on it that makes it longer.
Next, the fuel tank, Like JD said, the standard tank size, even back to my '92 is 141gals. Here is a pic from the '01 catalog
So the question is, did you see the tank tag? To replace the tank will entail cutting out the floor/sole to access the tank.  The newer years have a trace line in the deck, looks like a hatch but isn't.  It does give you a place to cut.
June 15, 2018, 09:59:20 PM
OK, I'm guessing you are seeing the tank manufacturer decal through one of the deck inspection plates correct and that you do not have a tank coffin cover, correct?
If so, it's pretty safe to assume your tank is factory installed but is smaller than what normally came on your model. They may have happened for several different reasons.
Line ran out of 141 gals. and subbed the 125 or the original owner requested a smaller tank.
Here are the dims. for the factory 141 gal that should have been originally installed and a custom 125 gal the member had made to replace it.
https://classicaquasport.com/smf/index.php?topic=11420.msg112287#msg112287
No matter which size you choose, you're in for a fair amount of work in cutting the deck for access and then using that piece to create a coffin cover.
Good luck. :thumright:
March 12, 2024, 04:07:17 PM
atbulloch
RickK My name is Anthony Bulloch I actually Have The same Exact Boat 26.1 FT Aqua sport 250 Explorer fuel Gauge is flashing like Tank is empty but tank is Full Have You had this Problem if so please help share your experience.
March 12, 2024, 08:39:54 PM
My boat is a '92 230 Explorer and the fuel tank is 141 gal. Your Subject indicates a 2011. Do you mean 2001?
Here is the '01 catalog
