Engines & engine woes
What to Do - Not a Good Day
Topic: What to Do - Not a Good Day (Read 579 times)
June 04, 2018, 10:02:56 AM
Read 579 times
Nfratino
June 04, 2018, 10:02:56 AM »
Just finished wrapping up my project last year (1986 osprey 22-2) along with a new tandem axle trailer. I was coming home late the other evening and i am pretty sure the motor went boom. She is locked (2000 Johnson 130). I haven't had any issues with this motor, always flushed it and she ran great. The oil tank has been consuming oil so i dont think the injection pump is bad. I am now stuck with deciding if i should spend the 12-15k to repower, find a used motor or part with the hull and find another boat. I have a hard time putting that much more money into a 30 year hull.....
June 04, 2018, 04:39:55 PM
jdupree
Re: What to Do - Not a Good Day
June 04, 2018, 04:39:55 PM »
First thing I would do is pull the heads. This will give you a good indication of what is going on with your motor.
John L. Dupree, III
AQABLA84E999
Member #257
June 05, 2018, 08:48:11 AM
Mechanical Master
June 05, 2018, 08:48:11 AM »
Before you pull the heads, check the gearcase and make sure it didn't lock up. I would be full of water and metal chips or burnt gear oil. I have seen blown gearcases stop a motor in its tracks and make you think the powerhead let go.
June 05, 2018, 12:20:21 PM
Nfratino
June 05, 2018, 12:20:21 PM »
Got the call today. Cylinder #1 piston has a hole in it. Mechanic says oil starvation so i am guessing my pump went up. Thinking about repowering with a Zuke 150. Has anyone gone this route/concerns with weight. I think the new Suzuki weighs around 500lbs, but the boat was rated for a 225 max.
June 05, 2018, 04:29:15 PM
jdupree
June 05, 2018, 04:29:15 PM »
Sorry about your motor. If the pump malfunctioned I would assume you would get some kind of alarm, and the damage to the motor would be more widespread than 1 cylinder. Sounds like to me that cylinder leaned out for some reason and was not getting gas/oil.
John L. Dupree, III
AQABLA84E999
Member #257
June 05, 2018, 11:45:03 PM
June 05, 2018, 11:45:03 PM »
I agree. A failed oil pump would destroy ALL the cylinders. Odds are that carb was clogged and went lean.... lean of fuel and oil... got hot and melted a hole in the piston. If that motor is carbureted then it has OMS (Oil Metering System) which is very reliable. I'd look for a used 150 Etec. Direct bolt on and lightweight. Or new one with a 8 year warranty. Also the Mercury 3.0L 150HP inline four cylinder is a solid proven motor that is rather lighteight for a four stroke.
June 07, 2018, 11:54:16 AM
Nfratino
June 07, 2018, 11:54:16 AM »
Decided on the zuke 150. The transom is in decent condition with no signs of cracking/hairlines. I called down to the guys at outboard specialties in FL and they have done a decent amount of 22-2 with this motor. I was a little skeptical going to a 500lb motor but the mechanic at the boat shop seems to think it will be fine. Any other guys out there running a DF150 on a 22-2?
June 09, 2018, 11:12:59 PM
Woodeneye
June 09, 2018, 11:12:59 PM »
I have a Yamaha F150 on my 222 CCP and it is just fine. Though I did move the batteries from the stern (always hated that spot) forward to inside the console.
