Aquasport Discussion
Osprey center console latch/door/access panel
Topic: Osprey center console latch/door/access panel (Read 803 times)
June 03, 2018, 12:14:01 PM
Read 803 times
NoQuarterNoMercy
June 03, 2018, 12:14:01 PM »
Hey guys. I’m looking to replace the large screw on piece that holds the two access hatches on the center console of my osprey 200. Its right in front of your knees as you’re operating the boat. Not exactly sure what to call that part...but it holds two doors that allows you to get to the batteries and what not under the console. A large chunk cracked off the bottom where it meets the floor and now there’s a crack in the middle. It’s gonna fall apart soon enough. Preferably just the one piece, but will purchase an entire console if need be. Anyone have any leads or resource to find one?
Thank you
June 03, 2018, 12:42:52 PM
Re: Osprey center console latch/door/access panel
June 03, 2018, 12:42:52 PM »
Is there any way to post a picture or two? There are great folks on this board who are happy to help, but I can't figure out what part you are talking about.
June 03, 2018, 01:29:44 PM
Global Moderator
June 03, 2018, 01:29:44 PM »
Pics indeed plus the year will help.
June 05, 2018, 01:55:47 PM
NoQuarterNoMercy
June 05, 2018, 01:55:47 PM »
Lets see if this pic works..
June 05, 2018, 01:58:33 PM
NoQuarterNoMercy
June 05, 2018, 01:58:33 PM »
Above is a pic....its not my console, but it is identical. Its the part that the door hinges attach to. Its got a big hole where it meets the deck and is cracked through where the screws attach it to the console. My hull is the 2001 osprey 200. Any leads? Its beyond repair...
June 05, 2018, 02:40:40 PM
Global Moderator
June 05, 2018, 02:40:40 PM »
If you have no luck locating this (again good luck with that) you may wish to try going the custom route.
https://www.boathelpshop.com/Aquasport-Products_c12.htm
If you remove the part and supply him with a pic, he may be able to do it. I don't know but it never hurts to try.
June 05, 2018, 04:12:32 PM
June 05, 2018, 04:12:32 PM »
Might be worth contacting Boat Outfitters. They build custom doors out of Starboard. Here’s one that looks like it would work on your console.
https://www.boatoutfitters.com/lift-out-door-with-toe-kick
It has an open toe kick, not a recessed one like yours, but looks like it would work. I bet if you sent them your door, they could get even closer.
June 06, 2018, 01:44:41 AM
NoQuarterNoMercy
June 06, 2018, 01:44:41 AM »
These are great ideas, thanks guys. I Didn’t consider unscrewing the whole thing and just getting a new door for it essentially. Time to take some measurements and see what I can find/make. 🤘🏻
