Author Topic: '87 222 rebuild  (Read 3664 times)
August 08, 2018, 03:19:32 PM
Re: '87 222 rebuild
« Reply #15 on: August 08, 2018, 03:19:32 PM »
I'm at about the same stage on mine. If you decide to go with coosa, give marine surplus a call. They had a few sheets left last time I was down there that were way cheaper than anywhere else. Some of them were a little scuffed up but nothing that you couldn't work with.
August 08, 2018, 04:45:43 PM
fishybish
Re: '87 222 rebuild
« Reply #16 on: August 08, 2018, 04:45:43 PM »
Last place I called yesterday, and sure glad I did so...Beat online prices by $200+ for 1-1/2 sheet."
1987 Aquasport 222 (In-progress) "Last One"
August 09, 2018, 06:51:11 AM
Re: '87 222 rebuild
« Reply #17 on: August 09, 2018, 06:51:11 AM »
Awesome, glad they had some left!
August 12, 2018, 10:36:20 AM
fishybish
Re: '87 222 rebuild
« Reply #18 on: August 12, 2018, 10:36:20 AM »
Transom grinding progress...How far back do I have to grind? Glass mat seems pretty solid on the transom.
Had to grind back farther in some areas due to water intrusion/glass delamination. How fair does this surface need to be prior to laying up the new glass?
Dished out holes...
Now, just trying to find time to get to FGCI between work and collect materials.
August 12, 2018, 01:48:45 PM
Re: '87 222 rebuild
« Reply #19 on: August 12, 2018, 01:48:45 PM »
It doesn't have to be real fair.
Oh, and save yourself some disappointment and read these links:
August 12, 2018, 06:56:38 PM
Re: '87 222 rebuild
« Reply #20 on: August 12, 2018, 06:56:38 PM »
Man that looks familiar! I did pretty much the same thing, ground out the mat that was delamed or wet and left anything that was stuck on well. I'm not too worried about how fair it is since I figured it's getting a good layer of thickened epoxy all over it before the core goes in which should level it out some. I did add a bit of csm to the bigger spots though just because I had it on hand.
