Author Topic: No sound at all when I turn the key  (Read 601 times)
May 15, 2018, 12:41:18 PM
Read 601 times
Pri123
  • Canada
  • 2003 Aquasport Osprey 175
« on: May 15, 2018, 12:41:18 PM »
Hi all...a few days ago everything worked fine and now there is nothing when I turn the key.  No sound at all, no starter, nothing.  I checked all the fuses and battery terminals and can't find anything.  The only think I did over the last few days is remove my old VHF radio which wasn't working anymore.  The batteries are full and the fish finders and GPS plotter all work.  The engine tilt works.  I just can't start it.
Any ideas?
Phil Riebel
May 15, 2018, 02:11:28 PM
Re: No sound at all when I turn the key
« Reply #1 on: May 15, 2018, 02:11:28 PM »
Neutral safety switch in control box, shift the engine to forward gear then back to neutral and see if it turns over. If it does, the neutral safety switch is bad or needs adjusting.
May 15, 2018, 04:40:20 PM
Pri123
  • Canada
« Reply #2 on: May 15, 2018, 04:40:20 PM »
Thanks...will give it a try
Phil Riebel
May 22, 2018, 08:52:54 AM
Pri123
  • Canada
« Reply #3 on: May 22, 2018, 08:52:54 AM »
Just thought I would confirm that it was a faulty neutral switch...we replaced it and it all works good now.  After I received your post I called the mechanic and told him to check the neutral switch...probably saved me a few hours of labor.  Thanks again!!
Phil Riebel
May 22, 2018, 09:07:41 AM
« Reply #4 on: May 22, 2018, 09:07:41 AM »
Glad it worked out - frankly that should have been one of the first things the mechanic checked.
One time I just launched my 230 and I tried to start it and got the same thing.  Ended up the helm chair had swung around and barely, but enough, moved the shifter out of neutral.  :oops2: That was NOT the first thing I checked unfortunately.  It will be next time.
June 30, 2019, 10:21:02 AM
BradC
« Reply #5 on: June 30, 2019, 10:21:02 AM »
Great tip, thanks. Wish I'd read this thread 2 weeks ago, might have saved a few hours of increasing frustration levels 👍
