Author Topic: Cracks in transom  (Read 770 times)
May 15, 2018, 11:45:42 AM
Read 770 times
Jchandler22
Cracks in transom
« on: May 15, 2018, 11:45:42 AM »
1987 200 Osprey here - I have a few sizable cracks in my transom.  How big an issue is this, and what's the suggested method to fix?
Thanks for any advice.
May 15, 2018, 12:33:44 PM
Re: Cracks in transom
« Reply #1 on: May 15, 2018, 12:33:44 PM »
The cracks along the top of the transom are normal and are showing where the liner comes up and over the top of the transom. You can seal it and as long as it hasn't had water intrusion, should last you a few more years. I've never seen a big crack on the side piece of the transom - if they stopped the wood short of the top I guess that would happen. If you want to use the boat as long as you can, seal it up good.
