What do you plan for power? Your flatty should be more fuel efficient than my CCP. I went with 58 gallons assuming that I’ll get 4-5 MPG at most efficient cruise with a 150-200. Assuming 4 MPG and 90% useable (52 gal) , that should gives me a range of 208 miles. Keeping 1/3 in reserve, that’s still 140 miles range, or more than enough for 30 miles out, 30 miles back and a full day of trolling.Make your plans based on your intended use.
I would flip it around. You'll want your fuel pickup at the rear end, otherwise when you throttle up and the fuel goes aft, you may not get any at the pickup tube. The bow will be rising as well.
