Author Topic: 1976 Proline Flatback Scooter Build  (Read 5591 times)
June 01, 2020, 02:30:40 PM
Reply #45
Richiebe
Re: 1976 Proline Flatback Scooter Build
« Reply #45 on: June 01, 2020, 02:30:40 PM »
Thank you
June 01, 2020, 03:34:14 PM
Reply #46
« Reply #46 on: June 01, 2020, 03:34:14 PM »
June 10, 2020, 09:53:34 PM
Reply #47
Richiebe
« Reply #47 on: June 10, 2020, 09:53:34 PM »
Anybody have prop recomendations, the prop on the engine now pushes wot and pretty slow i have looked over the entire prop and there is no numbers or name. Mercury prop selection says 4 blade 13x19 pitch.
June 11, 2020, 09:46:58 AM
Reply #48
« Reply #48 on: June 11, 2020, 09:46:58 AM »
If you post RPM at WOT you’ll get better answers.
June 11, 2020, 09:54:30 AM
Reply #49
TooLoose
« Reply #49 on: June 11, 2020, 09:54:30 AM »
Richiebe - sometimes if the prop specs will be on labeled on the hub (if a fixed hub). You can see this if you take of the locking nut on the prop shaft.
June 11, 2020, 10:00:44 PM
Reply #50
Richiebe
« Reply #50 on: June 11, 2020, 10:00:44 PM »
Unknow on full wot as it would run all the way up to 5000 and it wouldnt be complete wot and i would pull it back down to 3500, took prop off clean it up and looked over every inch of the prop there isnt one mark any where. It is a one piece prop i did check to see if it was bad prop hub put a paint mark on prop and hub took it for quick spin when i rechecked it the marks where about a 1/2" off so i bought a 4 blade 13x19 prop today will check it out this weekend.
June 12, 2020, 04:04:36 AM
Reply #51
« Reply #51 on: June 12, 2020, 04:04:36 AM »
Why only 5000 RPM?  I think that max RPM on the 115 Optimax is 5700.  Lightly loaded, your engine should be turning close to max.
June 12, 2020, 01:29:21 PM
Reply #52
TooLoose
« Reply #52 on: June 12, 2020, 01:29:21 PM »
I have a 115 but was in a similar scenario. Top end of the RPM range on the 115 was 6000, but with the original prop I was only seeing 5100 WOT.
I sent a note to Ken Reeves at PropGods who recommended a prop which got me up to 6000, increased my top end speed and helps with mid-range cruise.
I'd highly recommend contacting him if you are looking for a prop recommendation (kr@propgods.com)
August 20, 2020, 07:21:24 AM
Reply #53
Theboatcapt
« Reply #53 on: August 20, 2020, 07:21:24 AM »
So did I see this this guy for sale on marketplace or craigslist recently?... just wondering
August 17, 2021, 04:04:30 PM
Reply #54
sholcomb72
« Reply #54 on: August 17, 2021, 04:04:30 PM »
I have a skiff that I want to cut down like this and put a flat top deck on but im not sure how to roll the gunwale edge like this. Do you use a guide like a piece of PVC pipe?
2000 Osprey 215 Dual Console with 2004 Suzuki DF250
August 17, 2021, 04:34:20 PM
Reply #55
« Reply #55 on: August 17, 2021, 04:34:20 PM »
In this pic it looks like that may have been what he used. Look at rear corner.
