Hey all,
Looking for tips from other aquasporters with older outboards like myself. Motor is a 1990 Evinrude 88 SPL. Just like last year, my overheat alarm went off during spring commissioning. Last year I replaced the thermostats AND waterpump. Tell tale water was not warming up which led me to think the tstats were stuck closed. I removed the hoses connecting the tstat housing to the cylinder banks and got some vinegar down on the tstats and compressed the springs a few times. Re-ran the motor for about 15 minutes at idle and it DID NOT overheat this time but the water is still very cold.....odd? I'm thinking about installing a temp gauge to monitor cylinder temp so I can keep an eye on it BEFORE the alarm sounds. I've seen some senders you can just thread into a spot on a cylinder and run a sender wire up to the gauge. But i am also curios about this from Simrad
://www.simrad-yachting.com/simrad/type/accessories/temp-sensor-pk/?gclid=Cj0KCQjw8YXXBRDXARIsAMzsQuXjxUUawperCV_e9dlG7s8_6mR4ZvNh4NwrXkV_H0YEx2SARUjUWcAaAiLfEALw_wcB.
I could simply connect this into my N2k backbone but I am not sure where to mount it for the most accurate readings across all four cylinders. Any input here?
Thanks as always!
