Author Topic: 2003 Mercury outboard 115  (Read 362 times)
April 18, 2018, 05:26:13 PM
Read 362 times
Bencarpenter112
« on: April 18, 2018, 05:26:13 PM »
Went offshore today for a bit and managed to find my buddy stalking me at the reef on a hook and line later. Was a great day untilllll we were coming back in and the motor died spontaneously. Than woul crank and run WOT while pumping the primer bulb. Thinking this is a fuel pump issue? confirmation or thoughts?
1988 Aquasport Osprey 200
1987 Mako 17 (Sold)
1996 Palm Beach 18 Skiff (Sold)
April 18, 2018, 07:03:08 PM
boatnamesue
  • Jason
Re: 2003 Mercury outboard 115
« Reply #1 on: April 18, 2018, 07:03:08 PM »
Fuel pump or fuel line restriction.  Was the primer bulb normal or collapsed when engine died?
Jason
1976 AS 170
1998 S115TLRW
April 19, 2018, 05:21:28 AM
« Reply #2 on: April 19, 2018, 05:21:28 AM »
 :01_37:
So the engine would not run below WOT while pumping the bulb? Does not make sense as fuel restriction since the highest demand is at full throttle. So I'm thinking it is something else but more description may help.
April 19, 2018, 10:32:07 AM
Bencarpenter112
« Reply #3 on: April 19, 2018, 10:32:07 AM »
Fitz the motor was running fine at low or high rpm when pumping the primer bulb which is why my thought is the fuel pump itself. even when we elevated the line without pumping the ball i could get the rpms up for a bit before it died. Also everytime it would die the ball was empty.
1987 Mako 17 (Sold)
April 19, 2018, 12:45:28 PM
« Reply #4 on: April 19, 2018, 12:45:28 PM »
Sounds like clogged water separator, plugged tank vent or sticking anti-siphon valve if so equipped. To validate the fuel pump, try running on a separate 6 gallon tank to see if it still starves for fuel. The fuel pump rebuild kit is cheap <$50 and easy to do. Marineengine.com is where I shop for my Merc parts.
April 20, 2018, 02:41:57 PM
Bencarpenter112
« Reply #5 on: April 20, 2018, 02:41:57 PM »
checked the fuel water seperator and that was fine. checked all the fuel lines up in the motor and found a pinhole leak so replaced that and rebuilt the fuel pump with the kit. Ill let ya know how she runs tommorow. Thanks for the help
1987 Mako 17 (Sold)
