Author Topic: Old Engine Starting Woes  (Read 354 times)
March 24, 2018, 06:52:40 PM
Read 354 times
chataqua
  • Mid Atlantic
« on: March 24, 2018, 06:52:40 PM »
1978 Johnson 115 v4 ... starter seems like it's not getting enough juice to get high enough (elevation) to engage the flywheel to start.   After a few tries it would intermittently / rarely engage, but couldn't get it going long enough to get the old, cold engine started.   Looking for advice on what to troubleshoot between the battery and the engine for what appears to be not getting enough voltage to the engine.   I did run up to the store and buy a new battery.   After calling it a day, not getting her fired up, we took the batteries and had both tested.   Both appeared to be fine and charged.
March 24, 2018, 08:03:36 PM
boatnamesue
  • Jason
Re: Old Engine Starting Woes
« Reply #1 on: March 24, 2018, 08:03:36 PM »
Get yourself a digital multimeter if you don't already have one.  Since you've confirmed cranking battery if fully charged, next step is to confirm the starter is receiving 12v.  Use the meter probes at the starters terminals to check volts.  If good, use probes to test the starters resistance at the terminals.  If no resistance is detected and the starter is receiving 12v...replace starter.
Jason
1976 AS 170
1998 S115TLRW
March 25, 2018, 12:07:19 AM
chataqua
  • Mid Atlantic
« Reply #2 on: March 25, 2018, 12:07:19 AM »
Bought a meter tonight, will try and test tomorrow depending on weather.  Thank you.
March 25, 2018, 05:02:57 PM
NekoMich
« Reply #3 on: March 25, 2018, 05:02:57 PM »
Well, after some work today, the issue is in the ignition switch. At least we were able to get it up and running and went out on the water for a bit today!
March 25, 2018, 05:25:29 PM
« Reply #4 on: March 25, 2018, 05:25:29 PM »
Nice!
March 25, 2018, 09:59:26 PM
chataqua
  • Mid Atlantic
« Reply #5 on: March 25, 2018, 09:59:26 PM »
We hit a top speed of 43 MPH.  Not bad for a '78 boat / engine.  Face is feeling salty and wind burnt.   No better feeling :-)
