Author Topic: inboard location  (Read 708 times)
March 24, 2018, 10:41:43 AM
Read 708 times
barkdog
inboard location
« on: March 24, 2018, 10:41:43 AM »
I have a 1967 222c and will be installing an inboard  does anyone have the measurement from the inside of transom to bell housing to engine block join?   it would really help me locate eng. location fore/aft  and be much appreciated  thanks craig
March 24, 2018, 03:59:13 PM
Re: inboard location
« Reply #1 on: March 24, 2018, 03:59:13 PM »
You are going to have to measure this and determine it based on how the engine fits under the console.  Are you going with a reduction gear?  Which transmission are you planning to use -  are you going straight inboard or with an outdrive?  Power taken off the front of the engine or the rear?  All of these factors contribute to how you locate the engine, the angle of the engine on the hull, and need for a driveshaft or propshaft.  Lots of questions need to be answered before you are ready to measure distance from the engine to the driving system.
April 03, 2018, 06:53:32 PM
barkdog
« Reply #2 on: April 03, 2018, 06:53:32 PM »
I have built over 20 boats this advise is not needed  thanks
I STILL REQUIRE THE measurement ftom inside of transom to the flywheel/engine block joint
April 04, 2018, 05:26:36 AM
« Reply #3 on: April 04, 2018, 05:26:36 AM »
Since Aquasport didn't start offering an inboard until they came out with the 12 degree hull ('72/73), ('74 was the first inboard for a 22-2 http://www.classicaquasport.com/gallery/showgallery.php?cat=558) asking for measurements on a flatback (pre '72) model will likely produce nothing, since no one has one (unless someone home-made it, like you're trying).
GoneFission knew this and was offering info on what you'd need to do it from scratch.  Dig around in our 22-2 Osprey rebuild forum - lots of info in there. I do remember someone in Calif (I think) that added a tunnel and inboard to his hull. Maybe some else remembers this also and can dig it up.
April 04, 2018, 08:48:58 AM
« Reply #4 on: April 04, 2018, 08:48:58 AM »
You're thinking of this old thread:
https://classicaquasport.com/smf/index.php?topic=11119.msg108737#msg108737
Link to his pics:
https://get.google.com/albumarchive/104905260722286217761/album/AF1QipP1F2ZJcBtf_Wn57frTPFWt9DeSE0ooFcqmRGau/AF1QipOODXjJgeaqu6z04x5SB1vDBnCGO-ucdvzRuhkj?source=pwa#5907665073405177458
No dimensions that I can find. No need to waste time looking at the Flattie rebuilds cause no one (as noted) on this Forum has rebuilt as an inboard.
Having never built a boat, I'm curious as to the need for this dimension, especially since this is a one off custom. Hopefully BD will post up that measurement when he arrives at it for future members wishing to add an inboard drive to their Flattie. Again, clueless on boat building (I just drive em' ), doesn't adding that type drive kind of defeat the whole purpose of a flatback hull? :ScrChin:
Edit: Just thinking, you might try the ABC site. They have a guy who has built many boats. He may have what you're seeking.
http://www.theaquasportboatclub.com/index.php
April 04, 2018, 12:55:52 PM
dirtwheelsfl
« Reply #5 on: April 04, 2018, 12:55:52 PM »
Then why ask  :scratch:
Especially for a measurement with a ton of variables, in something that was never built (assuming its an actual 67 222)
April 04, 2018, 01:02:15 PM
« Reply #6 on: April 04, 2018, 01:02:15 PM »
I thought about going there but I refrained...
April 04, 2018, 04:27:17 PM
« Reply #7 on: April 04, 2018, 04:27:17 PM »
Got a PM from BarkDog on my attempted answer to his post:
"IF YOU CANNOT PROVIDE INFO REQUESTED YOU SHOULD KEEP TO YOURSELF!!!!!!!!!!!  YOUR REPLY IS USELESS                   blablabla to your wife or whoever will listen  not here thanks craig"
Nice huh?   :c029:
April 04, 2018, 06:07:32 PM
« Reply #8 on: April 04, 2018, 06:07:32 PM »
I didn't realize you had that affect on people CJ   ;-)
April 04, 2018, 07:32:02 PM
« Reply #9 on: April 04, 2018, 07:32:02 PM »
As they say in the U.K, "off you go then".
April 04, 2018, 07:59:22 PM
Woodeneye
« Reply #10 on: April 04, 2018, 07:59:22 PM »
or......"on your bike Guv"........
April 05, 2018, 07:43:57 AM
« Reply #11 on: April 05, 2018, 07:43:57 AM »
Well, I tried to be pleasant with my reply but I now realize that my reputation over at ABC will be tarnished even more since I sent Dog that Barks over there.  :nah:
