If the coffin on your 222 is like the coffin on my 20CCP, it is not a separate piece bonded in. It is a tub that is molded into the liner, all one piece. It should still possible to move it, though it may be a lot of work. Maybe rig some kind of ledge to support it on the inboard side of the stringers?
Sugg is right it's a molded fiberglass liner.
It’s expensive to set up the molds for Pollyethelyne. I doubt it was used in 1976. You can’t bond Polly to anything.not even 5200 sticks reliably to it. What makes you think it’s not glass?
Quote from: mshugg on November 20, 2017, 06:07:43 PMIt’s expensive to set up the molds for Pollyethelyne. I doubt it was used in 1976. You can’t bond Polly to anything.not even 5200 sticks reliably to it. What makes you think it’s not glass?It did not have the same stiff-like characteristics as fiberglass. And it incredibly thin, thinner than any glass built box I've known. When prepping the coffin for the new tank, I drilled 2 thru holes to allow water to escape. It was millimeters in thickness. You are spot on with your statement on bonding poly. Perhaps it is possible to mold a coffin with only a layer or two of cloth.
I thought you were sure it isn't fiberglass. My tub was the same way, it's fiberglass.
