Author Topic: '74 19-6 Transom Rebuild  (Read 1663 times)
September 21, 2017, 10:01:24 AM
Read 1663 times
burntsalt
« on: September 21, 2017, 10:01:24 AM »
Hello everyone. I've owned this boat for a few years and love the way she rides, so finally made the decision to start a rebuild. I don't plan to restore the whole boat at the same time, but rather take it piece-by-piece beginning with the transom. I'm definitely new to this, so any and all criticism and/or recommendations are greatly appreciated.
I'm using this boat as a learning tool in order to gain the experience necessary to do a yacht-quality rebuild of a 22-2. Hope she floats when I'm done!
She sat real nice previously, hope to keep it that way as the build progresses
Began by de-rigging...If anyone needs a great running Yamaha 115 with all cables and controls let me know, I'll sell it cheap!
Found a real nice 1/2 tower that will be going in. Plan to modify the existing console to fit the tower.
Here I began to cut away the deck...
And then the stringers...Very surprised to find the foam was super dry.
And finally the inside skin and transom cap. The wood core was about 1/2 solid and 1/2 soggy.
I'm a dentist and I've been looking at this project the same way I restore teeth...Remove the decay and replace with sealed materials that are resistant to further decay.
Used a hammer, crowbar, wide chisel and Bosch Bulldog Rotary Hammer with chisel attachment to remove the wood core from the outside skin. Not a fun job, but not as bad as expected with the rotary hammer. Finally used the grinder with sander attachment and 36 grit to clean everything up.
So this is where I am now. Although Ive cut back the liner on the inside of the hull about 12'' and cleaned everything up with the grinder a bit.
My tentative plan is to lay up a new inside skin, reinforce the outside skin and pour a full transom with Arjay Ceramic Pourable Compound. All criticism and recommendations are much appreciated!
1974 19-6
September 21, 2017, 11:31:48 AM
Re: '74 19-6 Transom Rebuild
« Reply #1 on: September 21, 2017, 11:31:48 AM »
Looks like your off to a good start.  At least the itchy part is out of the way.  I see your in St. Pete.  I'm in North St. Pete/ Pinellas Park area.  I get all of my fiberglass supplies from Fiberglass Coatings www.fgci.com.  With all the work you have done, I'd go with a composite board of some type instead of a poured transom. FGCI sells Kay-Cel a fiberglass reinforced polyurethane sheet.  I think it would be easier and probably stronger too.
September 21, 2017, 01:41:04 PM
burntsalt
« Reply #2 on: September 21, 2017, 01:41:04 PM »
Thanks Wingtime
My thought was that a poured transom would actually be easier than cutting out and laminating a core material, but are you suggesting Kay-Cel for a better end result or ease of use? Or both?
...We're definitely lucky to have FGCI in our backyard!
1974 19-6
September 21, 2017, 02:27:33 PM
« Reply #3 on: September 21, 2017, 02:27:33 PM »
With a poured transom you need to build a substantial inner skin and supporting structure to keep it from bowing inward when you pour the composite.  Laminating up an inner skin out of the boat and then tabbing it into the boat would be more work than just cutting out the core material and laminating it in place.  Then you just laminate your inner skin on top of that.
September 21, 2017, 06:01:21 PM
« Reply #4 on: September 21, 2017, 06:01:21 PM »
I second what Wing is suggesting.  Use Coosa 26lb 3/4"x2.
September 21, 2017, 08:05:55 PM
dirtwheelsfl
« Reply #5 on: September 21, 2017, 08:05:55 PM »
For a day or 2 :mrgreen:
x2 on using a traditional core...
September 22, 2017, 01:28:32 PM
burntsalt
« Reply #6 on: September 22, 2017, 01:28:32 PM »
Thanks for the input everyone...looks like I'll be changing my plan and coring this transom. I'm heading to FGCI today or tomorrow and I need a materials list. Any advice for a proper lay up? Planned on using polyester.
1974 19-6
