On another note, the surface of the hatches on the raised deck are in great shape.
Boatnamesue Thanks for the insight. I should have clarified when I said "raised deck," I was referring to the casting platform on the bow of the boat. Hard to describe over the forum, but I'll take my best attempt at it. In the picture below with the circle indicating the "problem area"... The floor is hard as a rock about six inches in from the console (from the console towards the gunnel) and another six inches from the starboard access tray (from the access tray moving towards the bow). It seems to be a small concentrated area. If the water was coming through the console screws, wouldn't the entire deck area between the console and chine be damaged?So far, I have had 3 forms of feedback - (1) no structural support with recommendation to fill the area under the deck with multiple layers of foam, (2) drill small hole and pump epoxy into the area to firm up, and (3) seal and move the deck. All of these would be outside of my comfort zone. It looks like you may be from the Tampa area. If so, is there someone you would recommend that I can have take a look at it?
