Engines & engine woes
150 ocean runner using to much oil
Topic: 150 ocean runner using to much oil (Read 510 times)
August 07, 2017, 06:47:57 PM
Read 510 times
Thunderhead
August 07, 2017, 06:47:57 PM »
I have a 98 200 osprey with a 150 ocean runner. The motor runs great, but uses 2 gallons of oil in about 6 hrs of running and smokes like a train. I had air in the fuel system due to a bad pick up tube, but that did not fix the problem. Any ideas?
August 07, 2017, 06:58:45 PM
1973aquasport
For the ocean is big and my boat is small.
Re: 150 ocean runner using to much oil
August 07, 2017, 06:58:45 PM »
1. Remove cowling
2. Start engine
3. Find massive leak (it will be the one spewing 2 gallons of oil)
https://classicaquasport.com/smf/index.php?topic=14428.msg142499;topicseen#new
August 07, 2017, 07:19:01 PM
Thunderhead
August 07, 2017, 07:19:01 PM »
There is no external leak. That would be to easy.
August 07, 2017, 07:34:55 PM
1973aquasport
August 07, 2017, 07:34:55 PM »
If I'm not mistaken, don't these Johnsons have a VRO (Variable Ratio Oiling) pump? The idea behind the VRO is that it vary oiling to 100 to 1 at idle and 50 to 1 at full speed. It sounds like yours might be malfunctioning and is pumping far too much. I'd try to see about a replacement pump.
August 07, 2017, 07:40:11 PM
Thunderhead
August 07, 2017, 07:40:11 PM »
The vro pump was replaced and has less than 20 hrs on it. I would hate to think the pump is bad already. I haven't had the chance to vacuum test the pump due to rain.
August 12, 2017, 07:24:37 AM
Thunderhead
August 12, 2017, 07:24:37 AM »
After doing all of the test procedures in the manual, it turns out to be a bad diaphragm on the fuel side of the vro pump. Replaced pump and good to go.
