Author Topic: 1975 222 Project  (Read 655 times)
July 31, 2017, 12:32:18 AM
Read 655 times
rackemup
1975 222 Project
« on: July 31, 2017, 12:32:18 AM »
Finally found her and found her close to home! 1975 222. Took delivery on her about 2 weeks ago and this weekend was the first to really tear into it. Plan is to take out the inboard, transom mount and outboard, have the appropriate fiberglass repair/recondition done, mid-tower. Started by taking out the fuel tank, parting out the motor, exhaust pipes, bilge pumps, rudder and took a whack at the drive shaft but couldn't the prop or the collar, that bolts to the motor, off. Those dang keys they use were giving me a hard time. If anyone has any advice on DIY work that can be done to keep costs down or any project advice in general, it'd be greatly appreciated.
August 11, 2017, 08:59:29 PM
minionsram
Re: 1975 222 Project
« Reply #1 on: August 11, 2017, 08:59:29 PM »
I would first before i turned any wrenches, spray every bolt nut and fastener down with pb blaster or kroil. Let it sit for a few hours and hit it again. Do this a day or two before your planned work. Those two penetrates will eat the corrosion and rust the best and give you a little less headache
