Author Topic: Reconfigure- 24ft  (Read 634 times)
July 11, 2017, 01:11:23 PM
Read 634 times
rackemup
Reconfigure- 24ft
« on: July 11, 2017, 01:11:23 PM »
I've been looking for an aquasport all over and came across one recently which is a 24 ft. cuddy. It looks like the hull itself is the same as a center console 24', but with the cap being the cuddy. Is re-configuring it from a side to center console and removal of the cuddy something feasible being the hulls appear to be the same?
Thanks for the help.
July 11, 2017, 04:14:33 PM
Re: Reconfigure- 24ft
« Reply #1 on: July 11, 2017, 04:14:33 PM »
It would be a big undertaking, but doable.  You would need to reengineer the forward cap cutting out the cuddy and rebuild a coaming.  You're also removing the liner, so you would need to add stiffness back to the hull.
There's a rebuild of a Kencraft 215 Walkaround to a CC on The Hull Truth, but I think the Photobucket issue has messed up the pictures.  You also may want to check out my 200 CCP rebuild.  It's not a cuddy, but I removed the liner to go with a cap & hull construction.  You can see some of the work that I'm doing to replace the stiffness lost when the liner is removed.
July 12, 2017, 03:05:45 PM
rackemup
« Reply #2 on: July 12, 2017, 03:05:45 PM »
To be honest, I have not done fiberglass work myself. If there is some cutting I can do to help decrease the labor for a fiberglass guy to do, I will. With that, does anyone know of a reputable fiberglass guy in the Houston area who has done work on aquasports or similar types of work?
July 18, 2017, 01:31:37 PM
ShawnsIronman
« Reply #3 on: July 18, 2017, 01:31:37 PM »
To be honest, I think that would be a huge undertaking. It may be more than what you want to take on.
On another note: I know of another 24 that is available in Baytown that would be an easier conversion. Here is the link to the ad: https://www.facebook.com/marketplace/item/1696914097270888
July 19, 2017, 09:18:50 AM
rackemup
« Reply #4 on: July 19, 2017, 09:18:50 AM »
Thanks ShawnsIronnman. Do  you happen to have a number for the seller?
