Author Topic: 1976 22-2 rebuild, factory inboard to outboard conversion  (Read 14058 times)
October 05, 2018, 07:05:53 PM
Reply #105
Re: 1976 22-2 rebuild, factory inboard to outboard conversion
« Reply #105 on: October 05, 2018, 07:05:53 PM »
Looking great! Catch ya in the spring.
October 05, 2018, 07:59:36 PM
Reply #106
Marcel4t
« Reply #106 on: October 05, 2018, 07:59:36 PM »
Hey, this is an awesome build.  I'm curious about your tank install, where did you source your neoprene and how did you make those straps?  Maybe if you have closer pics of the straps?  Thank you.
1971 222
October 05, 2018, 10:56:59 PM
Reply #107
theFunsmith
« Reply #107 on: October 05, 2018, 10:56:59 PM »
No way to get a portable carport to work under? You can make it a garage with some tarps.
It is bittersweet to shelve it for months, but it is hunting season, and I'm hungry for wild game. I was ready to take a break.
I sourced my neoprene from Amazon.com. The straps are 2"x1/4" solid neoprene, not foam. It is fastened in place with 2"x2" aluminum plates, with 4" stainless screws into coosa blocks and fiberglass.
May 15, 2019, 03:14:29 PM
Reply #108
theFunsmith
« Reply #108 on: May 15, 2019, 03:14:29 PM »
The weather is starting to come around up here. I will be uncovering the hull after memorial day weekend. I thought I would post some pics of what I have been working on in the mean time. Kind of freshen up the thread. The anchors necessary to river fish up here are quite a bit different than what I see most Aquasports equipped with. And being that I plan to put some fresh paint on in the not so distant future, I opted to weld my own from 316. I also gave another shot at making my bilge hatch and gutter. Quite a bit more successfully this time. I think this one is going to work. I will say though, it would have probably been a better idea to buy the thing after I added up the time involved. It certainly needs some fine-tuning but it is strong. Very much looking forward to getting it set into the deck.
May 16, 2019, 06:48:22 AM
Reply #109
« Reply #109 on: May 16, 2019, 06:48:22 AM »
Yup that is definitely a different type of anchor - looks good.  Good for rocks?
The hatch looks great.
May 16, 2019, 07:08:47 AM
Reply #110
« Reply #110 on: May 16, 2019, 07:08:47 AM »
Those both came out nice!
May 16, 2019, 12:36:20 PM
Reply #111
theFunsmith
« Reply #111 on: May 16, 2019, 12:36:20 PM »
Thanks, Mike. And Rick, you nailed it. They call these a Columbia river or "rocking chair" style anchor. Optimized for loose round rocks and steady fast water. The chain is zip-tied to the top of the anchor during normal use, but is able to break away and be pulled up from the bottom when you inevitably stick it on a log or in some other snag.
July 06, 2019, 02:48:53 PM
Reply #112
theFunsmith
« Reply #112 on: July 06, 2019, 02:48:53 PM »
I've been at it for a month or so, but hadn't been doing well at keeping the thread updated. Here are some good shots of the rebuild to bring it up to current. I have the bilge hatch installed with thickened epoxy and large-man-jumping tested. I installed the face for the stern enclosure/cabinet. The gunnel supports and anchor locker bulkhead are all complete and tabbed into place. I left the supports all slightly taller than necessary so I can remove material as necessary to get the cap to sit down into place nicely.  Next week will see some the cap come out from beside the house and we will see what can be done to massage it into shape and bring it up to snuff.
July 06, 2019, 02:53:43 PM
Reply #113
« Reply #113 on: July 06, 2019, 02:53:43 PM »
Great progress :thumleft:
July 06, 2019, 04:05:06 PM
Reply #114
« Reply #114 on: July 06, 2019, 04:05:06 PM »
Glad to see you’re back at it.  Looks great!  For a second, I thought that box at the stern was a live well with a window.  I was going to call you an over achiever, but now I understand.  Looks like a clean layout with loads of space.
August 12, 2019, 03:06:03 AM
Reply #115
theFunsmith
« Reply #115 on: August 12, 2019, 03:06:03 AM »
Another rebuild update, it was a great weekend for boat work. Had some mild temperatures and some good help from my brother. I buttoned up the back cabinet door, got the gunnel supports down to proper height. We got the cap test fit, stretched it out at the transom and massaged it a little bit to make it fit to the hull well. Then we got out all the rotten plywood and began the process of reinforcing it and recoring it with coosa. It felt really good to see the rough shape of a boat again. Ive got quite a few holes to fill in, and one more hatch to build for the bow before it goes on for good.
August 12, 2019, 06:12:55 AM
Reply #116
« Reply #116 on: August 12, 2019, 06:12:55 AM »
Good to see you back at it.
August 12, 2019, 07:50:08 AM
Reply #117
« Reply #117 on: August 12, 2019, 07:50:08 AM »
 :great02:
August 13, 2019, 08:14:37 AM
Reply #118
« Reply #118 on: August 13, 2019, 08:14:37 AM »
Great progress!  Your carpentry and glass work looks top notch.
September 26, 2019, 03:47:10 PM
Reply #119
theFunsmith
« Reply #119 on: September 26, 2019, 03:47:10 PM »
It has been a little while since the last post, but much has been done. The cap is all cored 360 with Coosa, and I built in a stout lip around the bottom of the gunnel. Now when I am "chumming" I've got something decent to hold on to. Now the boat has two more gunnel supports up at the casting deck, and it just looks more balanced. The fuel chase is buttoned up and installed.The anchor locker hatch assembly is about 90% built. The back arch of the cap is all glassed down, and the inside gunnel rails are blended to the knees/rear cabinet. This morning I ground out and filled the rest of the holes in the cap and I believe tonight's sanding will mark the transition from hull construction to beautification. Let the fairing begin.
