Aquasport Discussion
Deadrise vs. Performance
Topic: Deadrise vs. Performance (Read 2257 times)
February 25, 2005, 08:33:54 AM
Read 2257 times
February 25, 2005, 08:33:54 AM »
Have read some comments re. deadrise & performance but am still not clear on how each affects the other. My understanding is that AS cranked in the 12 deg sometime after the '70's boats. Comments I've read is that this affects draft. Since the O/B skeg is the deepest part of the boat anyway, what difference does the DR angle make? Was the change made to reduce pounding?
March 02, 2005, 09:12:41 PM
oystercatcher
March 02, 2005, 09:12:41 PM »
Don't know what year AS went to what deadrise, but can offer the following ideas re: deadrise and performance.
1. Higher deadrise creates higher draft, because a deeper deadrise angle displaces less water.
2. higher deadrise will (theoretically) pound less than a hull with less deadrise, but will tip more at rest.
3. higher deadrise requires more horses to move because more hull is in the water.
4. these are just generalizations, and performance of a boat includes lots of variables in addition to deadrise, like draft, weight, shape of chines, etc. YMMV, as they say.
\'75 22-2
March 03, 2005, 08:11:30 AM
March 03, 2005, 08:11:30 AM »
Thanks for the info. Oystercatcher. Where I fish draft isn't a problem but choppy/confused seas usually are. I've had a Whaler which is a great platform, but the pounding getting out & back can be brutal. I've been looking for a 17 or 22 cc but have just seen the Eastern 18' (
www.easternboats.com
) . Georgeous hull but not much beam & soft chines.
March 03, 2005, 08:15:36 AM
captin.kid
Guest
March 03, 2005, 08:15:36 AM »
anyone know the deadrise of a ccp???
March 03, 2005, 08:51:48 AM
Argo
March 03, 2005, 08:51:48 AM »
mine is 14^ as per the measurements requested by D&D marine for my twin bracket.
March 03, 2005, 07:02:31 PM
March 03, 2005, 07:02:31 PM »
Where in MA are you Oystercatcher? You see any 175's available up there?
March 04, 2005, 10:14:11 AM
oystercatcher
March 04, 2005, 10:14:11 AM »
I'm on the Vineyard. Very few A-sports up here. I know of two others in addition to the 22-2 I sold last year. Haven't seen a 17 in years.
Have you tried boattraderonline or boats.com?
\'75 22-2
March 04, 2005, 01:17:26 PM
Seadog
March 04, 2005, 01:17:26 PM »
Capt Kid - an easy way to figure the deadrise on your boat: take a framing square, put the long tongue at the one foot mark on the inside of the square, on the lowest point of the V, on the deadrise. The short tongue sticking up. The long tongue needs to be level with the rest of the boat - either eyeball or with a level if the the boat is level side to side. For every 1/4" of rise per every 12" of run = 1 degree of deadrise.
So 12.5 degrees of deadrise should read 3 - 1/8" on the short tongue.
This is only close and not exact. It's actually a little less than 1 degree of dead rise per every 1/4" of rise (45 dgrees is 12" rise for 12" run and there are fourty eight 1/4"'s in one foot, not 45) That will give you a close idea.
1970 Aquasport 222
Spring Hill, Fl.
