Author Topic: Hull Side Fuel Vent  (Read 409 times)
May 08, 2017, 11:51:22 PM
Read 409 times
boatnamesue
  • Jason
Hull Side Fuel Vent
« on: May 08, 2017, 11:51:22 PM »
Awaiting my new tank to be fabricated, I've taken the time to replace/reconfigure all the wiring in the boat.  Tracing a ground wire from console to inside the starboard circular access port (fuel fill hose & vent hose), I expected to find this ground wire connected to the fuel fill fitting.  It's not.  It's connected to the vent fitting.  Huh?
Shouldn't the fuel fill be grounded and not the vent?  I don't see why the vent would need grounding anyway, the gas station's fuel nozzle doesn't touch the vent.
Jason
1976 AS 170
1998 S115TLRW
May 09, 2017, 05:28:02 AM
Re: Hull Side Fuel Vent
« Reply #1 on: May 09, 2017, 05:28:02 AM »
You are correct the fill should be grounded not the vent.
