Author Topic: Risers welded onto bottom of fuel tank?  (Read 433 times)
May 02, 2017, 05:36:13 PM
Read 433 times
Uncutproducts
« on: May 02, 2017, 05:36:13 PM »
Need to get a new tank made for my 170. Perusing other peoples builds it seems like they usually bond something to keep it off the bottom of coffin for airflow. Would it be worth having fabricator add some sort of 1/4" riser block to bottom and hold down mounts on top or side?
May 02, 2017, 07:25:52 PM
Re: Risers welded onto bottom of fuel tank?
« Reply #1 on: May 02, 2017, 07:25:52 PM »
Usually you glue some starboard strips on the bottom but your idea on the top or side makes sense.
May 02, 2017, 10:30:06 PM
« Reply #2 on: May 02, 2017, 10:30:06 PM »
Odds are unless it it done just right your more likely to introduce stress points on the tank where cracking can start, creating another problem.  There are huge amounts of vibrations in a boat.  The tank needs to be able to float around a bit.  There is no PERFECT tank install, just ones where you can hope to avoid induced problems.
May 02, 2017, 11:45:01 PM
boatnamesue
  • Jason
« Reply #3 on: May 02, 2017, 11:45:01 PM »
I'm currently replacing the tank in my '76 170.  Your question and many others you'll eventually have are included in this thread.  You can follow along with my progress here:
https://classicaquasport.com/smf/index.php?topic=14275.0
The initial thread I started when I discovered the tank was leaking:
https://classicaquasport.com/smf/index.php?topic=14273.0
Jason
1976 AS 170
1998 S115TLRW
May 03, 2017, 10:31:26 AM
Uncutproducts
« Reply #4 on: May 03, 2017, 10:31:26 AM »
Thanks.
